Don please Step in(Audio nightmare)
Old Dec 24, 2006 | 10:36 PM
99 SE-L
Hey, i know you know your stuff therefore i want you to help me lol, I"ve sold my maxima back in may,now i drive a 03 Acura Cl, i purchased a Pioneer D1 Navi we wired everything up and i bought a line converter i still have a stock speakers (Bose), therefore a buddy and I located the stock Bose amp, tapped the Remote turn on it worked without a line coverter but my buddy said its not good without one, so we hook up the line converter(double checked the color code) and we are stuck any idea on how to get sound and bypass bose amps? Any help is greatly appreciated. Thanks in advance
Old Dec 25, 2006 | 12:53 PM
DcMaN's Avatar
you dont really need the line converter. As long as you play your music at a resonable volume. All you need to do hook the remote turn on from the headunit to the bose amp remote turn on wire. You'll be fine providing you dont blast your bose speakers. The speakers will be pretty loud at lower volumes in this situation. If you feel the need you can hook up the line out converter
Old Dec 25, 2006 | 02:11 PM
djfrestyl's Avatar
Suspension Yoda
Read the stickies. Splice some RCA's from your D1 preouts to your Bose line level inputs.
Old Dec 26, 2006 | 10:16 AM
99 SE-L
Why would i slice the preouts, when thats what the line coverter does???
Old Dec 26, 2006 | 01:58 PM
djfrestyl's Avatar
Suspension Yoda
You're not trying to bypass the Bose amp(s). You're trying to give it/them the correct signal.
Old Dec 26, 2006 | 08:47 PM
99 SE-L
SO how exactly do i do this, i have a 4 channel Scosche line converter.
Old Dec 26, 2006 | 10:12 PM
talisman311's Avatar
drop the LOC. get some cheap RCAs and cut the ends, and wire it up to the harness getting the signal from the preout vs. the high level. sometimes this gives you engine noise tho.. pre-outs are cleaner then the high-level. i don't know about rewiring to bypass the amp, the resistances on bose speakers are usually kinda weird. in nissan's case... 1ohm, which would overheat your D1.
Old Dec 27, 2006 | 08:21 PM
99 SE-L
Anyone else??
Old Dec 27, 2006 | 08:35 PM
kpr10is's Avatar
Read the Stickies, Car Audio FAQ, page 2, post by myself. I described the process in detail of adding an aftermarket radio to Bose, itll be the same for your Acura as a Maxima.
Old Dec 27, 2006 | 09:35 PM
Pearl96Max's Avatar
I tend to get a bit irritable
go to the factory amp, disconnect it, toss it in the street....add new amp.
/thread
Bose sucks, but in Acuras its surprisingly worse than Nissans.
Smackasmith
Feb 1, 2016 12:40 AM
trungg86
Sep 4, 2015 04:58 AM
