Need a 12v Source
Need a 12v Source
I figured I'd post this here, for all of you who are wiring gurus. I need a 12v source that will come on with the key in the ON position. I cannot use the cig. lighter because just recently it started to not get 12v. I don't know why. If you can explain that, that would be even better. I would love to use it, but I can't because it doesn't get 12v anymore (I traced it clear back to it's wiring harness, and it doesn't have 12v anywhere).
Another source I was using is too weak to power my RPM switch on top of it's current function, so I need a separate source. Thanks in advance!
Which fuse box we talking about? I never would have thought that to be safe, really. I was also kind of hoping not to have to run yet ANOTHER wire into my engine bay. I have a ton going through the firewall as it is.
I did it on my maxima. I tested every fuse under the dash to see which one would come on with the ignition on. Once i found it i tapped into. It's only powering up my af gauge and shift light, so it's not much draw. No problems so far.
Originally Posted by burnurass
maybe tap one of the radio wires for the ignition?
Also check the fuse for your cig. socket...maybe it's blown.
All good ideas.
you need to tap an ignition wire. look in the stickies of this forum on how to install a remote starter in a 4th Gen... it'll tell you what color (i forget), its underneath the steering wheel, you need to take your dash apart.
or, if you have a test light, you can grab the ign wire from behind your radio.
I just ended up replacing the fuse for the cig. lighter and everything is alright now
Still glad I got this thread going, though. I may need other 12v sources soon for other things, and I don't want to burden the cig. lighter again.
AaronL
Nov 15, 2020 11:52 AM
Hdnseek
Sep 9, 2015 05:55 AM
