I blew a 140a fuse pls help.
Old Jan 12, 2007 | 02:41 PM
Ricksi30's Avatar
I dont know how but when i changed my battery i blew the 140 amp Battery fuse. I purchased a new one from courtesy parts, but am having trouble changing it. So like an idiot i tried to pull it out with pliers and destroyed the plastic part. Now there are the two metal pieces exposed. Any ideas on how i can get them out?
Old Jan 13, 2007 | 05:19 AM
Afronaut's Avatar
Active procrastinator
Being it is more than likely the "anl" type fuse holder you just need to have the fuse connecting the two metal bases. Be sure to cover all exposed metal parts when u finish.
Old Jan 13, 2007 | 05:21 AM
Afronaut's Avatar
Sorry, I misread your post. I need more info.
Old Jan 15, 2007 | 09:54 PM
Ricksi30's Avatar
Any ideas?? If more info is needed let me know what you need to know more about.
Thanks -Rick
Old Aug 25, 2011 | 12:31 PM
cortez4973's Avatar
yeah I did the same thing it seems hard to get the fuse out at first but it's fairly simple. I have a 97 maxima and im just explaining to you what I did. First take the top of the box off. Then look at the bottom of the box and there should be between 4-6 little flaps that hold the bottom of the box, just take a flathead screwdriver and open each one, and also ther are like two hidden ones furthest from the battery. After you have gotten those off the bottom should slide down reveiling the two screws that are holding your fuse. Hope this helps you out with your problem
Old Aug 25, 2011 | 12:51 PM
AscendantMax's Avatar
this thread is over 4 years old...
Old Aug 25, 2011 | 01:00 PM
Goomz's Avatar
that'd be some **** if he was still in need of help for replacing a fuse 4 years later...
Old Aug 25, 2011 | 04:09 PM
Ricksi30's Avatar
Any ideas guys?
Old Aug 25, 2011 | 06:48 PM
Batxel's Avatar
blah
Originally Posted by Ricksi30
Any ideas guys?
Wait cortez4973 advice didn't fix the problem? Just be patient I'm sure someone else will chime in ......
Old Aug 25, 2011 | 06:54 PM
Crusher103's Avatar
man are you serious?
Old Aug 25, 2011 | 07:18 PM
Ricksi30's Avatar
Sorry guys sarcasm through text is sometimes hard to portray.
Old Aug 27, 2011 | 12:09 PM
1996blackmax's Avatar
Pretty funny!
Old Aug 27, 2011 | 12:20 PM
Goomz's Avatar
smdh rofl
Old Aug 27, 2011 | 05:41 PM
pahanorlando's Avatar
LOL, that was funniest thing I saw in a long time
Old Oct 3, 2011 | 08:58 PM
EsQueue's Avatar
Any ideas guys?
LLLOOOOLLLLL!!!! This made my night.
leatherneck
Sep 30, 2015 09:16 PM
kjlouis
Sep 14, 2015 11:22 AM
