New Prob. Lights dim when base hits
Old Jan 14, 2007 | 03:18 PM
Hexon's Avatar
Well now that I fixed my loose wire problem, my new issue is that when my volume is turned up loud my headlights and dome light slightly flicker when the base hits. I've never had this problem before, or at least not noticed it. I'm running a stock atl. and probably the stock battery. Should I just replace the battery with a yellow top or should I get a new alty. I don't want to spend much money, but I would like not to get pulled over by the cops for my lights flickering. Thanks.
Old Jan 14, 2007 | 03:21 PM
slickrick's Avatar
Umn do the big 3 and put in a new battery. My yellow top is nice...but for alot cheaper you can get similar results.
Old Jan 14, 2007 | 03:24 PM
Hexon's Avatar
What battery is similar but cheaper?
and by big three do you mean alty, battery, and cap?
Old Jan 14, 2007 | 06:51 PM
brynm's Avatar
Big three upgrade check out
http://www.the12volt.com/installbay/...TID=73496&PN=1
your best bet is an ho alt. the lights dim because your stock one can't keep up to what your amp wants, a cap will just mask this and can disguise problems, a yellow top or similar batt will help to a certain degree too. Battery upgrades are more for running the stereo with the car turned off, but will help some.
Your best deal on an ho alt is probably Nathan at www.excessiveamperage.com he does a 180 amp alt that uses all stock harnesses and brackets for about $360 shipped
Old Jan 15, 2007 | 09:08 AM
Hexon's Avatar
My stock alty might be under recall. I don't remember which alternators the recall affected though. Does anyone know where to check this out at?
Old Jan 15, 2007 | 10:06 AM
AnDyMaN's Avatar
if you're running BIG power, you should def. consider the HO alternator. My lights dimmed and stuff and after i got a bigger batter and the big 3, it doesn't dim any more. my system isn't that loud, so i got away with the battery and big 3.
Old Jan 15, 2007 | 10:39 AM
KyMan's Avatar
From what I've read, the big 3 on the maximas fix most dimming problems. Start with that, and you can get a newer, better battery if you still have voltage dipping problems. Big 3 is also the cheapest to do.
Old Jan 15, 2007 | 11:26 AM
Hexon's Avatar
okay, I guess I'll have to try it then. Should I buy a kit or make one myself?
Old Jan 16, 2007 | 08:03 AM
KyMan's Avatar
I wouldn't buy one, it's not hard to assemble the materials. I've read that some people have had good luck with welding cable from home depot. It's cheap (that's why they used it) but one drawback is that it's stiffer than 0 gauge speaker cable.
Maybe someone else with more knowledge will pipe up.
Old Jan 16, 2007 | 08:41 AM
slickrick's Avatar
I would not recommend 0 gauge from HD. If you use 2 or 4 gauge it should be fine.
Old Jan 16, 2007 | 12:23 PM
KyMan's Avatar
That's good to know.
I haven't done this yet, but I read up on it and think about doing it, but then I remember that my motorcycle needs love more than my car does.
BTW, it's way too cold here to be working on anything.
Old Jan 16, 2007 | 12:36 PM
slickrick's Avatar
its about 85 here...
Old Jan 16, 2007 | 03:27 PM
KyMan's Avatar
bastard. It was -1* when I woke up at 7 this morning and the high was like 14*. We aren't usually this cold-that's why I think global warming is a bull crap.
Old Jan 17, 2007 | 12:57 PM
mattj10's Avatar
haha, that sounds way too familiar
i was gonna do my install yesterday morning but when i looked at the thermometer and it read -24 i just went back to bed. and thats in southern minnesota..
Old Jan 17, 2007 | 12:58 PM
mattj10's Avatar
oh, and the maxima didnt like that cold too much either...
it was a rough morning
Old Jan 17, 2007 | 01:44 PM
KyMan's Avatar
I will never live in Minnesota. But, on a positive note, you guys have great hockey up there.
I'm moving to AZ (or maybe southern Cali) once I graduate from college. Then I can ride my motorcycle year round.
Old Jan 17, 2007 | 02:22 PM
mattj10's Avatar
oh, theres plenty of positives up here though...
...like the way living in minnesota makes me appreciate the climate in claifornia and arizona
Old Jan 17, 2007 | 03:33 PM
Hexon's Avatar
In east Tennesee it was 70 degrees last week. Now its in the thirties, and we might actually get snow.
tsi6001
Oct 3, 2022 10:23 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
