Which Infinity Speakers should I get?
I'm looking at two different Inifinity References models-6412cfp (
) and 6412cf (
) to replace the front bose in my 92 SE.
The only difference I see in the numbers is that the 6412cf has 40 watts RMS and 105 watts peak power handling and the 6412cfp has 45 watts RMS and 135 watts peak power handling. Has anyone had either of these speakers before? Is the 6412cfp that much better, or are they about the same. Also, I'm assuming both with fit in the stock speaker pods in the front, am I right in assuming this?
I would call Crutchfield to guarantee the fit. My choice would be the 4x6 6412cf. The plate speaker is going to give you an even smaller woofer than the 4x6 version. They both have the silk dome which imo always sounds great.
Originally Posted by Apollos2
I would call Crutchfield to guarantee the fit. My choice would be the 4x6 6412cf. The plate speaker is going to give you an even smaller woofer than the plate version. They both have the silk dome which imo always sounds great.
Originally Posted by hoyshnin
OK, I contacted crutchfield and they said they'd only fit with the non-bose brackets (none of their speakers actually fit the bose pods), i have the bose pods, so I have to get the brackets it looks like.
For the wiring, just snip the wires from the amp. You CAN infact use your stock wiring dispite what the morons at installation places tell you. Just figure out which ones are the speaker wires, clip/tape off the power lines, and simply bypass the speaker wires from the amp to your speaker. Do this for all fours, which is VERY easy to do.
For me, the 6x9" in the back provide plenty of bass, and I am very happy with the setup
Most of your quality sound is coming from the speakers up front and I would definitely recommend against 4x6 speakers or some tiny things like the plate speakers that fit a 4x6 area.
Your best bet is to buy 6.5" speakers.
You can either buy some custom made pods from James92SE or cut the Bose pods. There is room in the Bose pods to fit 6.5s (they have a 4" speaker stock, but it will fit), you just need to bypass the amp. I believe MrGone has a picture somewhere of how to cut them.
i've tried infinity's subs, coax's and components. Here's my take.
Infinity Kappa Perfect subwoofers were GREAT.
Coax/components....TOO BRIGHT/SHARP to really listen to loud. Get some POLKS for the same price or cheaper....they werent' as bright. Or save up for a nice rainbow SLC package or some DLS components.
litch
123
Jan 4, 2024 07:01 PM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
