component ohm loads.
Old Mar 28, 2007 | 04:38 PM
arkainshadow's Avatar
ok im confused, do tweeters hold an ohm load? if i had a 4 ohm component set does that mean, i have a 2 ohm speaker and a 2 ohm tweeter? or an 8ohm/8ohm? i cant seem to find this info. just 4 ohm systems. reason im asking is if you run a component woofer without the tweeter. is that bringing down the ohm load?
Old Mar 28, 2007 | 04:44 PM
AscendantMax's Avatar
the tweets are usually 4 ohms by themselves. same thing goes for the woofer. you can run the component woofer by itself without seeing a drop in the total resistance unless you wire another woofer into parallel. then the ohm will drop to 2 or so.
Old Mar 28, 2007 | 05:52 PM
nismos14's Avatar
§è~® f®ÈÄk
My slc tweets and my cal25's tested at about 2 ohm.
jmlee44
Oct 2, 2022 02:13 PM
RealityCheck
Oct 2, 2015 06:34 PM
bryants95max
Oct 2, 2015 12:52 PM
msellas
Sep 23, 2015 09:16 PM
