Help with ground location
Old Apr 5, 2007 | 11:31 AM
Blaximazx's Avatar
just curious , what part of the trunk are you grounding the amplifier too, I am having a problem of my amp cutting off when I notice I am playing a song with a lot of bass and the low note is loud.
Old Apr 5, 2007 | 12:55 PM
nismos14's Avatar
§è~® f®ÈÄk
Great title.............
Your ground has nothing to do with your amp shutting off.
Old Apr 5, 2007 | 01:28 PM
mendon99's Avatar
tastey wheat
need way more information.
how many subs are you running?
what are the vc configs, and how do you have them wired?
what's your gain set at?
install this yourself?
Old Apr 5, 2007 | 02:50 PM
DcMaN's Avatar
Theres a 99 % chance your clipping the amp and/or your woofers and its going into protection.
Old Apr 5, 2007 | 05:19 PM
sterlingmaxima's Avatar
Old Apr 5, 2007 | 09:27 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Title looks accurate to me.
And actually, yes it could.
Old Apr 5, 2007 | 09:47 PM
AscendantMax's Avatar
loose ground = sporadic connections = no consistent music/bass
i grounded my amps in the spare tire well.
Old Apr 6, 2007 | 05:15 AM
nismos14's Avatar
§è~® f®ÈÄk
First the title said J/L 500/1
2nd, the ground LOCATION has nothign to do with his amp shutting off... better?
Old Apr 6, 2007 | 07:31 AM
Pearl96Max's Avatar
Dunno whatcha talkin bout
Testy today? Someone **** in your cheerios this mornin?
Old Apr 6, 2007 | 07:41 AM
nismos14's Avatar
§è~® f®ÈÄk
Naw, forgot to add my smiley's lol
BTW I have headroom like a **** now sub channel with the ac gain down at 1/3 I still have to run it at -24 on the HU (time to re-adjust gains), thanks for the hookup on the ac. No noise either . Only issue I had was with those damned PG rca's, swapped them out for some others, no more noise
Oh and it's lucky charms, their magically delicious.
Old Apr 6, 2007 | 08:20 AM
honey bunches of oats > all
Old Apr 6, 2007 | 09:17 AM
mendon99's Avatar
tastey wheat
cinnamin toast crunch, actually.
Old Apr 6, 2007 | 09:24 AM
nismos14's Avatar
§è~® f®ÈÄk
No no no no no no no no
Old Apr 9, 2007 | 07:49 AM
BBOYSTEVIE's Avatar
Back from Hibernation
To answer the OP's question, mine are just in front of the spare tire well/behind back seat....(maybe more solid metal or more closer tie to main frame of car), of course paint sanded off, with a proper grounding block/terminal....this done by Don...no noise or shutoffs.
Old Apr 17, 2007 | 01:42 PM
Blaximazx's Avatar
Ok fellas, I found out that one my ground connection was loose (located by the jack storage bracket) so I rerouted the ground wiring to spare tire well, and I also re-adjusted the amp input sensor **** and I discovered that my cd player has a built in sub controls which the setting was set too high which was allowing my woofers to clip so the amp would shut off, I made the adjustments and everything is working fine.
Old Apr 19, 2007 | 08:18 PM
DcMaN's Avatar
lol so it was a little of both good guestimate on our part ; )
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
