Microvision screen no color?
Old Apr 22, 2007 | 08:14 PM
cardana24's Avatar
Blown
I just finished putting in a Microvision screen in my fourth gen...but I am not getting color. Everything else is working fine but the picture is not in color. I am running this screen with an Alpine indash DVD player. What would cause this? I hooked up the video line from the DVD player to the Screen with an RCA cable since it needed a male to male connection. Any ideas? Thanks.
Old Apr 23, 2007 | 06:28 PM
BLUEMAX01SE's Avatar
Does it have adjustments in the front or rear for color?
Old Apr 24, 2007 | 08:30 AM
cardana24's Avatar
Blown
I did not see an adjustment for color? If someone with a microvision screen wants to tell me different then let me know, but I did not see anything.
Old Apr 25, 2007 | 07:06 AM
cardana24's Avatar
Blown
bump
I was talking to a crutchfield advisor, he was saying that I need to make sure the screen is set to NTSC and not PAL, since they do not carry the screen he could not tell me how to do that. I did not know there way anything I could change like that. Any ideas guys? Also he said using a normal RCA cable would not cause the screen to be in black and white. Any ideas? The alpine I have is the DVA 9860 if anyone needs to know that.
Old Apr 25, 2007 | 10:50 AM
nismos14's Avatar
§è~® f®ÈÄk
Does the micro have a remote? Go through the menu's and check everything out tehre should be a setting for ntsc/pal.
Old Apr 25, 2007 | 11:03 AM
cardana24's Avatar
Blown
I bought it from Chris91SE here on the .org, he is checking to see if he has the remote. Is there any way I can check this with out a remote? I know when I load a DVD it should tell me if its set up for ntsc or pal. I'll check that later on.
Where can I buy a remote if he cannot find the one that goes with the screen?
Old Apr 25, 2007 | 07:52 PM
cardana24's Avatar
Blown
ok I checked it tonight and when I put a dvd in, it says video NTSC, so what gives? It seems to be set right. What could cause this?
Old Apr 27, 2007 | 07:46 AM
cardana24's Avatar
Blown
no ideas? I going to mess with this, this weekend. Any ideas would be appreciated.
Old Apr 27, 2007 | 07:51 AM
nismos14's Avatar
§è~® f®ÈÄk
Without a remote I don't know how you could mess around with any of the settings.
Is all the wiring in completely? Are you sure there is nothing wrong with the source?
Old Apr 27, 2007 | 08:21 AM
cardana24's Avatar
Blown
there are a few wires I did not hook up,
1) I did not hook up the power antenna wire
2) I did not hook up the Audio Interuption wire
3) I did not hook up the Remote In wire...this wire is supposed to go to the "Remote output lead"
4) I did not hook up the M. Cont wire...this wire is supposed to go to the Monitor Control lead
I did not hook up 3 and 4 because I was not familiar with those wires and I am not sure what wires I would hook to ( I know what it says but I don't know where to hook them up)
Would any of these wires un hooked cause me to loose color?
Old Apr 27, 2007 | 08:32 AM
mendon99's Avatar
tastey wheat
hook up the screen to another source, perhaps a portable dvd player.
Old Apr 27, 2007 | 09:00 AM
cardana24's Avatar
Blown
I don't have a portable DVD player
Old Apr 27, 2007 | 09:02 AM
nismos14's Avatar
§è~® f®ÈÄk
I'm starting to think it has to do with the wires that are not connected, I'm just trying to figure out how.
Old Apr 27, 2007 | 10:29 AM
cardana24's Avatar
Blown
do you know what the monitor control lead is? If it is one wire I am guessing its that one, but I don't know what the monitor control is, and I don't have an owners manual for the microvision. There are only four wires on the back of the screen. One is the video rca, one is a ground(ground wire in harness), one is hooked to battery power(yellow), and the other one is hooked to the ignition power(red).
Old Apr 27, 2007 | 10:36 AM
nismos14's Avatar
§è~® f®ÈÄk
It's probably a turn on signal ..... but then there is the other wire for that, I guess it could be used as a secondary switch/source?
Someone with experience with these chime iN???????
Old Apr 30, 2007 | 05:46 AM
cardana24's Avatar
Blown
I went and talked to Crutchfiled (where I bought the DVA9860) this weekend and had them look at my wiring. Everything looks fine to them too on the wiring. The wires that I have unhooked should not be hooked up for my set up. They told me that need to be able to look at the menu for the screen...well for that I need the remote, I do not have that. Does anyone know where I can buy just the remote, or does anyone know someone that sells Microvision screens...maybe I can contact them and get just remote. I could not find a website for Microvison, does anyone know what it is?
Also something to note is that when I switch source power to the radio, the screen will turn blue in color, then in redish letters it says No Signal. So its getting color from somewhere, but as soon as you switch the source power back to the DVD it goes to black and white. Any ideas yet?
Old Apr 30, 2007 | 05:51 AM
nismos14's Avatar
§è~® f®ÈÄk
Are you sure its not your dvd player?
Old Apr 30, 2007 | 06:46 AM
cardana24's Avatar
Blown
no, but it is brand new. I do not have another screen I can test it with...if I just had another screen to hook to it would be a lot easier. I may try to find a small TV from around the house that has a video hook up, and plug that in to test it.
Old Apr 30, 2007 | 07:05 AM
nismos14's Avatar
§è~® f®ÈÄk
Have you messed around with the settings on the dvd player itself?
Old Apr 30, 2007 | 07:31 AM
cardana24's Avatar
Blown
I've looked at everything I know to look at. It does not appear to have a setting to control the color output.
Old Apr 30, 2007 | 07:36 AM
nismos14's Avatar
§è~® f®ÈÄk
Interseting... damn good luck man, I guess its time to find a mv remote.
Old Apr 30, 2007 | 08:42 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Check the primary yellow composite connection. If its loose or not fully connected it could cause this.
No DVD players or VCRs in the house to use?
Also just because the HU is brand new, doesnt always mean its flawless.
Old Apr 30, 2007 | 08:52 AM
cardana24's Avatar
Blown
yeah I do have a VCR/DVD, I can try that.
What is the "yellow composite connection"? I know that the male connections are plugged all the way into the female connections, are you talking about something different?
Old Apr 30, 2007 | 09:02 AM
Pearl96Max's Avatar
Composite = RCA.
Old Apr 30, 2007 | 09:04 AM
nismos14's Avatar
§è~® f®ÈÄk
Try a different set of them too just to be safe and cover all bases.
Old Apr 30, 2007 | 09:44 AM
cardana24's Avatar
Blown
I have already tried 3 different RCA cables. I currently have a cheap video cord on there. I have also tried a low noise street wires regular audio cable, and then some other cheap rca. I am getting the same thing with all of them.
Old Apr 30, 2007 | 09:57 AM
Pearl96Max's Avatar
Then definately try a different source. If the problem remains its the monitor, if gone then its your HU.
Old Apr 30, 2007 | 10:41 AM
cardana24's Avatar
Blown
I'll try hooking up my home DVD player in the car tonight, and I will report back.
Old May 1, 2007 | 10:08 AM
cardana24's Avatar
Blown
I hooked up my home DVD player in the car (plugged into my power inverter and hooked up the yellow video cable) and everything is still in black and white when the DVD is playing. So this means I am having a problem with the screen. Does anyone have the proper wiring instructions for the screen. I am going off what another org member told me. I hooked the yellow wire to the battery power, I hooked the red wire to the ignition power (switched), and I hooked the black wire to the ground wire in the wiring harness. I think this is right but someone can correct me if this is wrong.
If all of my wiring is good are there adjustments on the microvision that could cause this problem? I do not have the remote, but the seller told me he thought he had it...so I am waiting on that. Anyone know about this?
Old May 1, 2007 | 10:13 AM
Pearl96Max's Avatar
If its still Black&White then its a monitor issue. The setting adjustment *may* help, but somewhat doubtful. Its seems as if the monitor itself has an issue, but wait for the remote and give it a try.
Old May 1, 2007 | 10:30 AM
cardana24's Avatar
Blown
this is my first microvision screen. What is there to be adjusted? The previous owner said he never had problems with it. Is there a color adjustment built in? Do you know where I can buy a microvison controller if he cannot find his?
nismos14's Avatar
§è~® f®ÈÄk
^ word to what Don said.
The screen DOES have color because you said you saw the blue screen and red lettering. I'm assuming somehow the screen got switched into the wrong mode. You NEED the remote, wait on that and then lets see.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Oct 28, 2019 10:58 PM
BobTX10
Oct 7, 2015 08:43 AM
