HELP!!! How do I crimp 4 gauge power wire??
Old Jul 11, 2001 | 09:04 PM
j2chan's Avatar
i'm trying to install some amps. Having trouble crimping the wire to the piece that attaches the wire to the battery though. Anyone? Anyone? thanks in advance.
Old Jul 11, 2001 | 10:18 PM
niceorange's Avatar
Thats a non-insulated loop I presume. I believe most wire stripers dont have a non-insulated crimper for anything above 10 gauge thickness, but when I did mine, I think I placed the end on a board, then hit a screwdriver with a hammer into the collar. If it's a good fitting, it should be a seamless collar, and therefore you should get a decent crimp. If worse comes to worse, torch it and solder, then cover it up with color matching heat shrink. It'll look fine.
Old Jul 12, 2001 | 08:29 AM
jashick's Avatar
I crimped 4 ga. wire to a ring terminal using 2 pliers.
One with a semi-sharp edge to crimp the actual wire and
the second to squeeze the handles of the first.
Old Jul 12, 2001 | 02:38 PM
Botos's Avatar
Use a vise if you've got one, or go bum a favor off your local shop.
Old Jul 15, 2001 | 08:19 PM
ray89se's Avatar
even better get a 4 guage ring term with
a screw down... screw there pretty cheap
The Frye
Sep 2, 2021 11:03 AM
cruce91
Sep 20, 2015 10:23 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
