new radio and ground loop noise ?
Hi,
I just installed a new pioneer radio. I had a couple years old sony in there that was installed by the previous owner. The old radio was going bad so bought a new DEH-P780MP. Now I have the ignition/idle noise throught the speakers. I tried to isolate it yesterday to see what it could be but had no luck. I did run into something weird with the antenna. But first here is the setup. The deck is connected to the stock wiring using a connection harness. I hooked up the red ACC wire, the yellow BAT wire and the blue ANT/AMP wire. Yesterday I ran a ground wire all the way to the battery. Before that I had it going to the metal frame that supports the radio and AC?Heater controls. The rest of the wires I capped off. I have three sets of RCAs running to two amps in the trunk. Power wires are on the left and RCAs are on the right going to the amps.
So now for the antenna question. When I unhook it, the radio makes a loud distorted noise, even when playing a CD. Is the radio getting grounded throught the antenna? Why? Tonight I am going to try to run a seperate set of RCAs over the seats to one of the maps to see if anything changes. But I would appreceate any help or sugestions you guys have. Thanks,
John
John
Hey there John, I think one of the main things the pros will tell you is to have a proper ground setup. A short run to the actual frame of the car is the best thing (at last from what I've read and have been told). You'll want to grind/sand down the paint from the frame to expose the bare metal and use that point as your grounding point. They will most likely tell you to use that single point for all of your grounds for your various pieces of audio/video equipment.
Hope that helps, and hopefully the other experienced posters will speak up.
Good luck.
Good luck.
Good luck.
Good luck.
John
Originally Posted by nismos14
Hopefully not the case, but you may have a faulty headunit with bad pre-outs.....
John
Only the ones you touch,
The main question is why they didn't fix the problem into the new run.....
Yea right. Thats why I try not to 'touch' them...
Because that would only serve the greater good, not put more money into their pockets.
Well tried everything and still ground noise. I did hook up the speaker just throught the deck and there was no noise. So the RCA output out of the deck is bad. I will try to contact Pioneer to see if they have a fix or what they recommend. I will keep you guys posted.
John
John
You tried grounding the rca's too?
Otherwise I hope you bought it authorized and get a warranty fix.
John
Fixed It
Well finally fixed it. To make a long story short I shielded the RCA pigtail. One of the guys at work just said put some tin foil around it, so I did. Actually I wrapped the whole pigtail connected to my RCA cords in tinfoil. I than stripped a 16 AWG wire about a foot and wrapped it around the tinfoil to act as a drain wire. I than hooked this wire up to the case of the radio. I than wrapped the whole thing in electrical tape nice and tight. NO MORE NOISE! For some reason the connections on the pigtail were picking up noise. I turned the radio all the way down and reved the car just to make sure and it was quite. I want to say thanks to all who gave me ideas here.
John
John
Originally Posted by AscendantMax
cool, glad you fixed the problem. what kind of rca's are you using?
