Looking for a box design...Atlas 15
Old May 11, 2007 | 07:29 PM
WhiteA32's Avatar
Hi,
I am currently using a 3.2 CU FOOT ported box tuned to 35HZ.
I want to run a sealed setup for a while, so I can gain some trunk space back.
I am not sure what size of a sealed box I want. But I only listen to rap music.
Basically I want it so I can use my trunk.
Let me know if anyone needs more information.
Old May 11, 2007 | 07:35 PM
AscendantMax's Avatar
try 2.0 NET sealed. your sub roughly displaces .2 cu ft, so make a box that's 2.2.
had my 15 in a 2.0 net sealed, and it sounded pretty nice.
Old May 11, 2007 | 10:05 PM
WhiteA32's Avatar
You had a Avalanche right?
I might have to call up Chad ( I think thats his name ) and ask him about it.
Thanks dude!
Old May 11, 2007 | 11:47 PM
slickrick's Avatar
2.4 cubes gross should give you sick low end...
Old May 12, 2007 | 08:38 AM
WhiteA32's Avatar
Ill look at that
Old May 12, 2007 | 08:47 AM
slickrick's Avatar
what is your goal in sub bass reproduction? If you want 60hz and down go with 2.4-2.5 gross and it will be more low end than you can imagine. If you want efficient bass in the 40hz and up to about 80-90 with emphasis on the high end make it around 2 cubes...can't you change the QTS on the Atlas though?
Old May 12, 2007 | 09:29 PM
WhiteA32's Avatar
Not sure about the QTS, All I know is that there are 2 terminals on the Atlas. One is gold and the other is silver. I know I am suppose to send power to the silver ones. IIRC the gold terminals are connected together at the moment. I forgot what this setting does. But I do remember you telling me on aim what it meant. hmmmm There was 3 settings for that gold terminal. One was nothing connecting them, the other was with a resistor, and last was connecting it with a wire....
Ill prolly go for a 2.4-2.5 range for box size. Whats a good height I should go so that the 15 can fit comfortabley in and I don't break the wood cutting the circle... IIRC the cut out on the atlas is 14.4in I was thinking somewere along the lines of 16 inches but not sure.. any input?
Old May 12, 2007 | 10:05 PM
slickrick's Avatar
16.5 to be on the safe side...since you were tuned to 35 like I was with my ava 15...if you want that ridiculous peak in output at 40hz and up...soot for around 2.1-2.2 gross. Yeah I'm rusty on the atlas settings but give Chad a call.
Old May 13, 2007 | 05:38 PM
WhiteA32's Avatar
By anychance someone wouldn't have his number. I don't have it anymore and its not on his website.
Old May 13, 2007 | 08:59 PM
slickrick's Avatar
Nah I just erased it from my phone about 2 weeks ago...
Old May 14, 2007 | 08:52 AM
WhiteA32's Avatar
damn...
I'll google that ****
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
Stagnet04
Sep 14, 2015 11:28 PM
