questions...help me!
Old Jul 13, 2001 | 11:20 PM
MikeyMax's Avatar
How do you take out the rear speakers on a 95 Maxima?
Does anyone have any info on the Clarion TV tuner? I have the DRX9675z and want to get a TV for it, but I know there are two types of tuners, one with CEnet and one without. IF I get the one without CEnet, will I still be able to use the speakers in the car?
Old Jul 14, 2001 | 05:59 AM
MaineMax's Avatar
OK - You need to remove the back seat and shelf to get to your rear speakers.
1.) Remove the rear seat bottom cushion. ( Pull on the 2 plastic rings on each edge. )
2.) Remove the 2 bolts on the outside edges of the seat back.
3.) Fold down the arm rest and door behind the arm rest. Lift the carpet and remove the 2 bolts. Push up on the seat back to remove.
4.) Remove the 3rd brake light assembly.
5.) Pull back the door edge molding.
6.)Pry out on the rear pillar trim panels to release the clips. Let them hang by the rear seat belts.
7.) Pry up the rear deck panel and slide it toward the front to remove.
8.) Now you can get to your speakers
Good luck.
Old Jul 15, 2001 | 07:32 AM
MikeyMax's Avatar
thanks man...!!!
Good luck.
