RCA Interconnect Length
Old May 28, 2007 | 05:07 AM
Digital Alchemy's Avatar
Create From Nothing
Haven't seen a post for this yet. Does anyone know how long I should get the interconnects from the H/U to a AMP for a 4th gen max. I'm planning on running the power down the driver side, and the RCA down the passenger side. Just want some opinions
Old May 28, 2007 | 06:48 AM
Torgus's Avatar
25' RCAs should be plenty...if that is what your asking. 20' would work as well but you might be more limited where you can put your amps in your trunk...
if your going to be seperating all the wires why not run the RCAs down the middle, POWER and Remote down the driver's side and the speaker cables from the amp to the front sound stage up the passenger's side...? make sure you get shielded speaker cable and actually ground the shield. ground your RCA's shielding as well. electrically that would be the best solution afaik.
oh and when you do you install do it once and do it right. and what i mean by that is take your time, make it look good, make sure everything is secure and correctly fastened down, MAKE A GOOD GROUND, and don't cheap out on parts: if you were thinking you would only need 8awg get 4awg etc it will save you the rewire you'll need in 6 months and a bunch of headaches when your wondering why this amp or that amp shut off and your tearing it out every weekend finding a wire fell off or a remote became disconnected etc...
good luck. let us know what system your going to be running...
Old May 28, 2007 | 07:00 AM
mendon99's Avatar
tastey wheat
20' is plenty, 25 is almost too much. hell, even 18 and 17 should be enough..
Old May 28, 2007 | 07:13 AM
Kevlo911's Avatar
Kevlo for President
20 is PLENTY.
Old May 28, 2007 | 08:21 AM
Pearl96Max's Avatar
I tend to get a bit irritable
17' will suffice. 20' if ya want em mounted on your taillights.
Old May 28, 2007 | 08:38 AM
Create From Nothing
ive been looking at the Stinger Hyper Series. I originally wanted to go with red wiring, but it seemed like everytime i turned around I kept getting blue wiring (amp kit came with blue and clear, blue 0gauge stinger for big 3 upgrade). So I think I might switch. I'll probably go with 1 set of 4 channel and a set 2 channel interconnects.
Old May 28, 2007 | 08:41 AM
Pearl96Max's Avatar
That would be the Helix line, available in 4 and 2 channel and is Red.
Old May 28, 2007 | 08:56 AM
Create From Nothing
Yea but I want everything to match so I'm going with the Hyper line (4 Channel; 2 Channel). is there any difference between the lines except cosmetics
Old May 28, 2007 | 10:13 AM
Pearl96Max's Avatar
yea, Helix is more money.
Old May 28, 2007 | 10:51 AM
Create From Nothing
ok the Hyper is $24 and the Helix $38. what causes the difference in price ...ohh never mind
Originally Posted by eBay
7.5mm cable diameter, foil and braided shield for noise rejection and molded stopper plus inner molded strain relief on RCA ends for superior reliability and great looks.
ohhhhhhhhhhhhhhhhhhhhh
Old May 28, 2007 | 10:53 AM
nismos14's Avatar
§è~® f®ÈÄk
IIRC, the hyper is directional too.
Old May 28, 2007 | 11:06 AM
Create From Nothing
both are directional both have OFC, but the Helix has all of those wonderful, extra, spectacular features that you just cant live with out WOOOOOOOOOHHHHHHHHHHHHHHHHOOOOOOOOOO
Old May 28, 2007 | 11:13 AM
Pearl96Max's Avatar
Its all marketing ...
Old May 28, 2007 | 11:14 AM
nismos14's Avatar
§è~® f®ÈÄk
Hmmm didn't notice that the hypers were. Guess I should have checked when I installled
Old May 28, 2007 | 11:21 AM
Create From Nothing
yea its directional, i didn't even know what that meant until yesterday
Originally Posted by carDomain
The Hyper series utilizes the latest in interconnect technology at an affordable price. Directional twisted pair design eliminates radiated noise from entering the system. An extra shield plus mylar foil wrap also contribute to the noise rejection capabilities of the Hyper series. The RCAs are 24kt gold-plated and come with split tip center pins. The Hyper series is finished in a unique translucent blue jacket. 17 feet in length.
9aj9
Apr 5, 2020 12:11 AM
bumpypickle
Sep 19, 2015 01:07 AM
jcvgn
Sep 13, 2015 11:42 AM
beerman1378
Sep 8, 2015 02:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
