New Head Unit hook up help...
Old Jun 4, 2007 | 09:08 PM
I30FlyHigh's Avatar
So I was just given an Alpine IVA-D310 today. I went to wal-mart...Yea I said it, Wal-Mart, and pickud up the wire harnes, mounting kit, and a 1500 watt amp hook up kit from Scosche. I get my center vents, change holder (A.K.A. Ashtray), and climate control out of the car.
I stsrt to run the wires for the Brain of my IVA-D310 and come to realize, due to the fact that there is a DVD player in this unit, I have to hook up a Yellow and Black wire to the E-Break wire, and the yellow and green wire to my pedle break.
Now this is all fine a gravy, EXCEPT, I have Zero, Zip, Zilch Clue on where to find these wires.
Please help!!!! Does anyone have any Idea on where I can find these two wires so I can get my music back with some DVD and Navi going as well? Please help!!! Please!??!
Old Jun 4, 2007 | 09:35 PM
The Law's Avatar
I R The Law
DON TO THE RESCUE!!!
*Turns on the Pearl96max light*
Old Jun 4, 2007 | 09:40 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Brake wire: Red/Green at the pedal switch
E-brake : I dont recall the color, but its at the ebrake itself.
Old Jun 4, 2007 | 09:46 PM
AscendantMax's Avatar
holy big sig pic batman!
Old Jun 4, 2007 | 09:47 PM
Pearl96Max's Avatar
Ugh didnt realize that was the sig. Original poster you need to modify that .. Alot.
Old Jun 4, 2007 | 09:54 PM
I30FlyHigh's Avatar
I;m Compinsating...How ever you spell it. Real quick... The pedle switch would be located right at the pedle correct? Yea I know, I'm a genius...
Old Jun 4, 2007 | 11:05 PM
2AZN2DMAX's Avatar
Just get a PAC TR-7 black box so you can watch TV while the car is moving and you don't have to do that whole sequence (brake/e-brake/let go etc...) I have the W200 and it comes in handy when you want to adjust on the go. If you want to be cheap hook the brake pedal wire up as usual but put a toggle b/t the ebrake wire and a ground spot. Then all you have to do is press the brake, flip the toggle on then off, then let go of the brake pedal, then bam picture is on while driving. Also those wires are only needed to view video not audio CD's and NAV. My 2 cents
Oliver
Old Jun 5, 2007 | 06:08 AM
I30FlyHigh's Avatar
Thanks for your info. I might do the toggle switch thing. For now, Just ran into a new issue. The harness that I picked up, doesn't fit the plugs in the car. Now I am going to go the long way and hook it up directly... I belive I saw a post on how to do that. Let me go look...
Old Jun 5, 2007 | 06:54 AM
nismos14's Avatar
§è~® f®ÈÄk
Oh PLEASE just get the correct harness and do the install. Do not chop off the oem harnesses! You can easily use the one from wal-mart as all the harnesses are the same from 95+ (if not older)
Exchange it for another one at wal-mart.
Old Jun 5, 2007 | 09:52 AM
I30FlyHigh's Avatar
lol... I didn't chop the wires in the car. I stopped the install and put the BOSE back in because I need to find the "GREEN" wire? for the pedle brake. I was under the dash looking around and found a few green wires. I don't want to cut into the wrong wire. I cauldn't figure out which one was which due to the aftermarket s****y install of the remote started and alarm.
Let me ask... There are four plugs from the BOSE. Only two of them fit the harness I picked up. The harness is for 74+ Nissans. I grabed the right one?
Old Jun 5, 2007 | 10:13 AM
nismos14's Avatar
§è~® f®ÈÄk
IIRC there should only be 2 bigger harnesses that plug in thats it.
Old Jun 5, 2007 | 10:28 AM
I30FlyHigh's Avatar
Thats what what I got. It just seems to get stuck at a setain point. Not all the way in. You know? I will have to go and retry. Post some pics as well.
So I had to edit this post.
Here is the deal, I was just reading some posts on page 8 or 9. Come to find out that i am going to need to pick up some other harnesses to run the BOSE Speakers. So. My install has come to a complete stop untill I find these other harnesses. This sucks.
Old Jun 7, 2007 | 11:05 AM
overbo0st2k4's Avatar
whats the link to the other thread you're looking at? I need to do this sometime this/next week also and am researching and getting everything I need prior to taken everything apart.
BTW, did you find a FAQ or something that tells you where the screws are and how to take the stock radio out? I tried searching but it was to no avail =/
Old Jun 10, 2007 | 09:22 PM
I30FlyHigh's Avatar
I did see a thread on direct wire. It was for the 5th gen. If you have a 4th gen. the screws are easy to get to. This is what I did.
Removed the panel by gear shift.
Removed ashtray.
Removed climate control
There are all the screws. two on top, two on bottom. two on each side of the radio. These two will remove the radio from bracket.
Old Jun 11, 2007 | 12:53 PM
I30FlyHigh's Avatar
So I found something out today. What this was is the fact that the Worcester MA. Best Buy car audio installer had no Idea that our STOCK BOSE radio has an extra harness for the bose speakers.
Just thought I would share that info.
Old Jun 11, 2007 | 12:56 PM
nismos14's Avatar
§è~® f®ÈÄk
How could he not know? Did he even look at it ? Or did you do it on your own? Every harness that comes for nissan's has 2 plugs.
Old Jun 11, 2007 | 12:59 PM
Pearl96Max's Avatar
What a moron..
Old Jul 19, 2007 | 06:33 AM
I30FlyHigh's Avatar
moron huh. I see that being helpful was out of the picture for you. I want to thank people like Pearl96Max for being such a nice guy.
Old Jul 19, 2007 | 07:33 AM
nismos14's Avatar
§è~® f®ÈÄk
Well wouldn't you say the bb installer was a moron? It's not liked you asked a question in that post.
Old Jul 19, 2007 | 07:46 AM
Pearl96Max's Avatar
You would like me to help how? What answer to the non existant question is it that you were looking for?
You dont think he is a moron? He does this for a living and on a car that has been in production for 12 YEARS and didnt realize something that simple?
Old Jul 23, 2007 | 05:03 AM
I30FlyHigh's Avatar
I was just putting my two cents up in a post for those of us who don't know about the functionality of the BOSE set-up. When you do not go through any training for installs and never have pulled a BOSE headunit before, seeing the extra plugs kinda throws you off. All in all, the Alpine is in and working great. I did a bypass so I can watch the DVD in motion.
I didn't do the bypass. A buddy did.
Thanks for everyones thoughts and help.
Old Jul 23, 2007 | 01:35 PM
Blacksmith's Avatar
I have searched and searched. I cant figure out how to remove my stock Bose head unit. I just want to replace the head unit to start. I know what I am doing, but just dont know the order of removal of the parts (i.e.-vents downward or ashtray up). I dont want to break something by forcing it. Any instructions would be appreiciated. I have a 2001 SE w/Bose. And I do believe that anyone that does installs for a living would know all that is needed to be known for a project, have someone to ask, or just not do it. Its common sense that 'morons' dont posess!
Thank You from a newbie that searched with no luck.
Old Jul 25, 2007 | 05:17 PM
stephenyi's Avatar
I was just looking for the same thing and found this:
http://www.nicoclub.com/articles.php?id=157945
Old Jul 27, 2007 | 12:14 PM
Blacksmith's Avatar
fantastic!!! Exactally what i was looking for. Thanx!
aw11power
Oct 10, 2021 04:57 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
