damaged Sirius antenna **PICS**
Old Jun 6, 2007 | 08:06 AM
pbn85's Avatar
Hey everyone...so for the past 2 weeks my Sirius radio has been acting up and says "linking" on the display. I checked all the connections and everything seemed good. Then I checked the antenna which I have mounted on the trunk (yes Jeff dont say "i told you so" lol). The wire is all damaged.
I called up the tech support and they were of no help. Does this look like a simple fix? Would all I really need is a new antenna w/ wire to connect to the reciever? Will any antenna work or do I need a specific one?
Let me know if you guys need more info..thanks
-Rahul
Old Jun 6, 2007 | 08:07 AM
kpr10is's Avatar
Any style Sirius antenna will work. Should be about 30 bucks at your local BB, CC, or other stereo shop.
Old Jun 6, 2007 | 09:03 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Should be just a simple splice with another Sirius antenna, although you *may* lose some signal by doing this.
This is one of the reasons I Always mount em Inside the car.
Old Jun 6, 2007 | 09:08 AM
BlkMaxNCa's Avatar
Go to RadioShack they have replacement anntennas for 30 bucks.....I know i used to work there......
Old Jun 6, 2007 | 09:18 AM
kpr10is's Avatar
I never take the chance. If the customer buys a new antenna, Ill run the whole new antenna. Usually isnt too time consuming.
If I had a dollar for every Sirius or XM antenna Ive replaced, Id be retired. They suck.
Old Jun 6, 2007 | 09:21 AM
Pearl96Max's Avatar
I agree, but then again I would not have mounted outside to begin with. It seems as if intentions were to just splice anyway, so I didnt see a point in directing him to do it the right way.
Old Jun 6, 2007 | 10:23 AM
burnurass's Avatar
Hey now...remember...he has sirius...he NEEDS it outside. XM > sirius......
:flamesuiton:
And yeah rahul...I TOLD YOU SO!!
Old Jun 6, 2007 | 10:52 AM
Pearl96Max's Avatar
This Is true....
Old Jun 6, 2007 | 04:07 PM
pbn85's Avatar
so this is what happened:
I bought the new antenna and wired it up really nice and neatly. Then the "linking" display went away but instead an "invalid channel" prompt came on. So I was on tech support w/ Sirius for an hour and they couldnt figure out what was wrong. They resent a signal 4x w/ no luck. So I took out all the cables for 5 mins and then re-inserted them. I finally got a good signal.
Maybe later on I will consider mouting the antenna inside. Where inside do you suggest? yea...XM is nice but Sirius is what came with the car and it works fine now.
Old Jun 6, 2007 | 04:08 PM
pbn85's Avatar
yea I ran the whole new antenna
Old Jun 6, 2007 | 04:53 PM
burnurass's Avatar
for sirius I would mount it outside. A GOOD SPOT with no moving parts would be on top of your roof somewhere. On the trunk lid is waiting for a wire to get SNAGGED if not done correctly. I put mine on the desk right behind the clock close to the windshield. But I have XM
Old Jun 6, 2007 | 05:59 PM
DOHCtorJT's Avatar
I'm using an XM antenna with my Sirius. Simply because it was on the car when I bought it and I was lazy Located on the roof above the windshield, before the sunroof.
But I have an extra sirius antenna if you need it. $15 shipped sound fair?
Old Jun 8, 2007 | 08:33 PM
illlojik's Avatar
I C U
you naughty boy you.....
Old Jun 8, 2007 | 08:35 PM
illlojik's Avatar
I C U
It's happened to me before, all I did was a simple splice and everything worked perfectly with no signal loss. (If there was I sure as heck never noticed )
litch
123
Jan 4, 2024 07:01 PM
chisam14
Nov 6, 2018 08:56 PM
Marc2theMax
Sep 28, 2015 08:13 AM
DBear
Sep 14, 2015 08:33 PM
