where to buy 0 gauge crimp-on ring terminals
Old Jun 19, 2007 | 08:15 PM
goldtooth's Avatar
I only found some at Circuit City- 5 for $20
What places do you know of that can beat that price? Cuz that price seems kinda steep(or is that just me?). Anything good online? I keep searching ebay, but Circuit City comes out as the better buy. This is for a grounding kit I am going to make, as I have 8 feet of 0 gauge wire.
Old Jun 20, 2007 | 12:47 AM
Froggmann's Avatar
Don't know about crimped connectors but making soldered ones is prety easy. All you need is a small blowtorch some solder a little bit of flux some heat shrink tubing and the right size lugs. Basically you clamp the lug into something that isn't going to burn heat the lug, put some flux on to clean the lug then melt some solder into the lug. Remove heat insert wire and hold for 30 seconds. your done.
Had to do this on my alternator for the Bronco. 160 amps doesn't flow right through 10 ga wire.
Old Jun 20, 2007 | 11:11 AM
mooze's Avatar
try ebay.com
Old Jun 20, 2007 | 11:18 AM
goldtooth's Avatar
Originally Posted by mooze
try ebay.com
try reading and comprehending at a third grade level
Old Jun 21, 2007 | 03:03 AM
sc0tty8's Avatar
I bought a bag of like 20 pieces with boots for something like $6 off of ebay last time I needed them.
We found that when using them, that, using stinger 1/0 wire vs raptor 1/0 wire, there is a difference in size, I had read somewhere that stinger uses over sized wiring, not sure if its true, but, we did open up the 1/0 crimps and they worked fine
Old Jun 21, 2007 | 05:58 AM
Sprint's Avatar
no need to be mean.. he just didn't read the whole post..
anyway.. this was the first link on my google search
http://www.allelectronics.com/cgi-bi...Terminals.html
Old Jun 21, 2007 | 06:02 AM
Sprint's Avatar
here is another from google
http://www.mpja.com/Category/Car_Aud...D_14914_TM.asp
10 for $6.99 .. now i guess it depends on if shipping is a factor
Old Jun 21, 2007 | 08:44 AM
goldtooth's Avatar
that was an awesome find Sprint! Thanks
with shipping it comes out to $14.33 for 10. Now this come out much better than 5 for $20
awww crap, i need a minimum $15 order.......
Old Jun 21, 2007 | 09:39 AM
slickrick's Avatar
have em charge you $.66 more?
Old Jun 21, 2007 | 10:59 AM
goldtooth's Avatar
but i dont think it includes shipping? cuz the item itself is 6.99....aww
Old Jun 21, 2007 | 11:54 AM
maximized98's Avatar
Addicted to the Org
Walmart and autzone has them. I know autoze is 2.99 for a pair. And I'm not sure about walmart. I did the same thing, made my own grounding kit.
Old Jun 21, 2007 | 04:17 PM
sc0tty8's Avatar
You can also go to the battery section of a parts store and get copper lugs, those you can heat up, put solder in, and slide a stripped end of the wire into it.
Here are a few off the bay....
http://search.ebay.com/search/search...trypage=search
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
DBear
Sep 14, 2015 08:33 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
