all 4th gens!
Old Jul 12, 2007 | 08:22 AM
blimblam's Avatar
all 4th gens!
for those with sub enclosures in your trunk, what are the dimensions? and did it fit into the trunk opening?
i was thinking 36"W x 14"H x 18"D but i dont know how to accurately measure the max depth and height to fit it into the trunk opening.
Old Jul 12, 2007 | 08:49 AM
Fast1one's Avatar
The biggest I fit with the torsion bars in place was 36 wide, 14 high, and 26 deep, fairly easy to get in and out (other than the whole weight thing). If you remove the torsion bars and install shocks im sure you can go 15 high and probably 16...
Old Jul 12, 2007 | 08:50 AM
nismos14's Avatar
§è~® f®ÈÄk
I hope your sticking an enclosure in thats built for your particular woofers.
Old Jul 12, 2007 | 09:25 AM
blimblam's Avatar
yes the enclosure is built for my woofer.
26 deep? you had no trouble fitting that into your 4th gen???
Old Jul 12, 2007 | 11:23 AM
blimblam's Avatar
anyone else??
Old Jul 12, 2007 | 01:38 PM
blimblam's Avatar
...i know someone has a 4th gen with a sub enclosure in it. or at least had.
Old Jul 12, 2007 | 01:46 PM
nismos14's Avatar
§è~® f®ÈÄk
Well ya but not all of us have used the entire trunk... I had a tiny as box in my 4th gen in the driver rear 1/4.
Old Jul 12, 2007 | 01:59 PM
blimblam's Avatar
well, i just want to get an idea of height and depth possible. i know that i can use up to about 37" but im only doing 36". now all i need is the height and depth.
Old Jul 12, 2007 | 03:28 PM
Fast1one's Avatar
IIRC I had a bout an inch between the top of the box and the torsion bars, though I did have a piece of wood under it so that raised it a bit, you should be fine with 15, and yes I fit 26 deep...
Single 15, dont point up BTW, loose a good amount of sound and you get a **** load of rattles...
Old Jul 12, 2007 | 03:40 PM
blimblam's Avatar
cool thanks man. yea, i heard that if the trunk lid sucks on maximas. why don't you deaden it? im planning on facing them towards the tail lights anyway.
Old Jul 12, 2007 | 07:56 PM
Fast1one's Avatar
deadening doesnt really help when you have a 15 firing right at it, trust me...
Old Jul 12, 2007 | 08:50 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
py problem now...sigh...didnt consider that just was so glad to run the ports straight up through the speaker holes...sigh..working on glassing a series of angled rings to change the direction in the setup a little.
Old Jul 13, 2007 | 12:12 AM
maxgtr2000's Avatar
KH3 by popular demand
Fiberglass ftw!!! My enclosure is for 2 12z and it is on the driver side of the car and is a vented box. You might notice that the max gets slower once you put all that wood weight back there, so I went with fiberglass.
http://forums.maxima.org/showpost.ph...7&postcount=17
Old Jul 13, 2007 | 07:07 AM
blimblam's Avatar
that's nice. do you have a picture of it carpeted or anything? or did you just leave it like that? only problem i have with fiberglassing is that im having my enclosure made for me then shipped to me.
Old Jul 13, 2007 | 08:55 AM
Fast1one's Avatar
The box I had weighed in at about 100 pounds, plus 50 pounds of subwoofer, sucker was heavy...On stock suspension it lowered my car about an inch
Old Jul 13, 2007 | 10:40 AM
blimblam's Avatar
i hope mine won't weigh as much..
Old Jul 13, 2007 | 09:07 PM
maxgtr2000's Avatar
Right now I just left it like that. It's been that way for almost 2 years since I don't do shows anymore. Havent really messed with it cause I would have alot of sanding if I decide to paint it. I might just carpet it tho.
For a standard box I would just measure the width between the trunk hinges, and the clearance from the truck floor to those trunk bars or whatever you call them. If i remember correctly I think it was around 32" or 34" wide for the last standard box I made.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
