Alpine sub hookup
Old Jul 30, 2007 | 10:17 PM
rvaladez34's Avatar
Alpine sub hookup
I was going to ask a question about how to best wire my alpine swr-1222d to my RF, but I guess the point is mute since I now want to have two of those subs. The problem is I need a sub I can run at 2 ohms in order to be able to power both of them with my RF.
In short, does anybody have an Alpine swr-1242d they'd be willing to trade for the 1222d version
Old Jul 31, 2007 | 05:49 AM
filtor1's Avatar
I don't think anyone here runs Type-R's. You may have better luck over at www.caraudio.com
Old Jul 31, 2007 | 09:32 AM
Robert_J's Avatar
I think you mean "moot". Mute is a button on my TV's remote control.
-Robert
Old Jul 31, 2007 | 12:01 PM
filtor1's Avatar
Indeed.
Old Jul 31, 2007 | 12:45 PM
Bollwerk's Avatar
I think you mean "moo" .. as in a cow's opinion .. nm
Old Jul 31, 2007 | 01:28 PM
jrpaytonAlpha06's Avatar
I have two I purchased last year. I'll sell one to you, really don't need to trade right now.
Old Jul 31, 2007 | 01:30 PM
mendon99's Avatar
tastey wheat
why not run it at 4?
Old Jul 31, 2007 | 01:47 PM
^^^good catch. It'll save you time, money and most likely trunk space. OP, what are the ratings of your amp?
Old Jul 31, 2007 | 02:49 PM
filtor1's Avatar
1/2 power.
Old Jul 31, 2007 | 03:10 PM
That's true, but some Rockfords run 1000rms @ 4ohms. Depends on what amp he has and how much power he'd be sending the sub. We would need to know the specs of his amp.
Old Jul 31, 2007 | 05:58 PM
rvaladez34's Avatar
First things first. Seeing as how Robert saw fit to answer my question with an attempt to correct my grammar, I think it's only fit to offer a rebuttal. Mute (I'm pretty sure) comes from a Latin word that means dumb, and can still be used in that context, (see my first comment). Given the context, usage of the word is completely valid in how I used it. Furthermore, mute is not a button on your TV's remote control, the mute button is. Now, that "mute," usage has been settled, I'll try to get back to my issue.
jrpaytonAlpha- how old are the subs? any damage, superficial or internal?
I have a RF 750s. I don't have the certificate anymore, but if I remember correctly, the amp was rated at least 925+ Watts rms at 2 Ohms. I'm running the sub at 4 ohms right now, but that means I have to bridge the channels and set the gain low to get the best out of my sub without popping it.
I wanted two subs for the extra bump, and should be able to run two at 2 ohms. The type r's are not too expensive and can really bump. they're the best bang for the buck, literally. I'm also gonna look into porting my enclosure. I have a sealed enclosure that i made, but the one i made for my brother sounds a lot better
Old Jul 31, 2007 | 06:09 PM
slickrick's Avatar
I nominate the 1st argument for "most pointless" of the year in the audio room...and trust me I know, I make plenty of bad/pointless arguments.
Old Aug 1, 2007 | 03:42 AM
mendon99's Avatar
tastey wheat
Originally Posted by filtor1
1/2 power.
it wold hold him till he got a new 1 ohm stable amp,.. or another sub.
Old Aug 1, 2007 | 06:19 AM
I purchased them March of '06. I had them in my other car for about a month. I blew the first box I had made so I switched to one sub in the trunk sending 1000rms(responsibly) to it. I'm using the other R in a ghetto fashion as my home theater sub after my original sub failed. Sending ~350rms to it.
Even if you got another one from me, you would have to upgrade your amp though.
Old Aug 1, 2007 | 06:41 AM
Robert_J's Avatar
First things first. Seeing as how Robert saw fit to answer my question with an attempt to correct my grammar,.....
I should have put a smiley. But you got a free bump and some answers.
And if you are willing to look at internet only brands, then there are dozens of options for subs.
-Robert
Old Aug 1, 2007 | 06:57 PM
rvaladez34's Avatar
1000 watts rms? what sub is this? not the type r, you would have popped that easy. it's rated for 200-500 rms. even with the gain and bass low a spike would kill the sub. what do you mean by responsibly?
I'm pretty sure my amp could drive the subs. i put in my brother's once, so i had two type rs, and even at 4 ohms i got a decent bump from them, so at 2 ohms it should be right around where it should be.
I may have to sell the sub and get two new ones. anyone interested?
also, when a volume is called out for an enclosure, is that with the sub in it, or is that for the volume of free air?
Old Aug 1, 2007 | 07:04 PM
rvaladez34's Avatar
i thought about maybe getting one of those newer shinier amps, but i would still need another sub. besides i like my setup right now, i think it sounds great, very efficient too, i just need some bass
Old Aug 2, 2007 | 07:06 AM
Responsibly means not driving your amp into clipping and not abusing bass boost or not using it at all.
I knew someone that had a Orion 2500 D @ 1ohm on two Type R's, but that's a little excessive to me. However, you can drive those subs on 1000rms daily. Don't take my word for it, you can see for yourself.
http://www.realmofexcursion.com/videos.html
Old Aug 9, 2007 | 10:07 AM
Jokester66's Avatar
I have 2 type r's 12' hooked up to a 1000bd RF amp, i get a good bump out of them with gain 66% up. I used to run Punch HX'2s they hit harder but the type r's overall are better sounding. i have them wired to 2 ohms.
Fbana41
Aug 29, 2016 12:18 PM
melteye
May 16, 2016 12:02 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
MaineI30
Oct 22, 2000 07:39 PM
