speaker install
Old Aug 13, 2007 | 06:09 AM
da big cheese's Avatar
speaker install
any write-ups on speaker replacement/install?
Old Aug 13, 2007 | 05:56 PM
nismos14's Avatar
§è~® f®ÈÄk
1) Remove door panel
2) Remove speaker
3) Deaden
4) Mount mdf ring
5) Caulk/deaden seal
6) Wire up speaker
7) Mount speaker
8) Put door panel back on.
Old Aug 14, 2007 | 09:01 AM
burnurass's Avatar
2) Remove speaker
3) Deaden
4) Mount mdf ring
6) Wire up speaker
7) Mount speaker
Thanks...that was VERY helpful.
Old Aug 14, 2007 | 09:08 AM
nismos14's Avatar
§è~® f®ÈÄk
Your welcome. :P
Old Aug 19, 2007 | 02:42 PM
viperxiv's Avatar
http://forums.maxima.org/showthread.php?t=528508
The hardest part is removing the small trim from around the door handles... don't let it get you down though.
Old Aug 19, 2007 | 03:14 PM
mach999's Avatar
I don't mean to hijack the thread but is there any other way to run new speaker wires through the rubber conduit through the door? I see how the poster in the link above did, just curious as to how everyone else did it?
Thanks.
Old Aug 19, 2007 | 06:21 PM
viperxiv's Avatar
I didn't use the conduit, there is a rubber gamut / giant washer-filled opening located a ways below where the conduit goes into the door. You can push it down or peel it back or whatever and feed the wires through there. It's really tight and the rubber is tough and it can hurt your fingers, but other than that it I found it be the perfect place. The wire will come at the same level as the back of woofer.
Old Aug 19, 2007 | 07:26 PM
mach999's Avatar
Did you drill a hole in the car where the wire exits to get to that point in the door, or how did you run it? I'm just a little worried about the wire getting pinched not being in the stock rubber housing.
Old Aug 19, 2007 | 09:52 PM
viperxiv's Avatar
No drilling... the wires work fine. To get the right length after you run the wire just open to door all the way and pull the slack out of the wire ...but not too tight. There is plenty of space in there, no worries. If you have more than one wire tape them together.
Old Aug 21, 2007 | 11:30 AM
what if i want to go with aftermarket speakers? dont u have to remove the individual amps and all?
Old Aug 21, 2007 | 09:12 PM
viperxiv's Avatar
If you have a Bose system there are amps, I don't know much about that system.
Old Aug 22, 2007 | 05:16 AM
nismos14's Avatar
§è~® f®ÈÄk
There's a single amp in 5th gens. You don't have to remove it, but you do need to either bypass it, or keep the oem spaekers and integrate into a new HU.
Old Aug 22, 2007 | 07:46 AM
i have a pioneer hu installed right now so if i buy the new speakers and install em; i'll just have to run an amp to them? is that right?
Old Aug 22, 2007 | 08:44 AM
viperxiv's Avatar
Yep and new wires...
Old Aug 22, 2007 | 09:00 AM
DcMaN's Avatar
no... wrong. You dont NEED to run an amp. You could run all the wires to the back of the headunit and just use the internal amp inside the headunit.
Old Aug 22, 2007 | 02:48 PM
AscendantMax's Avatar
Thanks.
i took the grommet off in my 6th gen. i just left the grommet hanging without either ends attached to the car or door and just snaked speaker wires through the grommet with a clothes hanger. then i popped the grommet back into place.
Old Aug 22, 2007 | 04:28 PM
mach999's Avatar
Did you go through the molex?
Old Aug 22, 2007 | 07:44 PM
viperxiv's Avatar
Yah... but it would be a shame to spend all that time (or money) running new wires only to run them to a deck.
Old Aug 22, 2007 | 09:39 PM
what molex?
Old Aug 22, 2007 | 09:48 PM
filtor1's Avatar
what molex?
Molex
An expensive watch worn by a child molester, usually in an attempt to create a respectable image. The term is derived from Rolex, a manufacturer of luxury watches. The effect is ruined if accompanied by a molesterstache.
Gary Glitter wears his molex while cruising in his molestermobile.
Information obtained on urban dictionary.
Old Aug 22, 2007 | 10:16 PM
Originally Posted by filtor1
Molex
Chris...me thinks you need some sleep...
Old Aug 22, 2007 | 10:17 PM
filtor1's Avatar
Indeed. I am on my way.
Old Aug 22, 2007 | 10:22 PM
nice post non-the-less, had me going wtf? haha
Old Aug 23, 2007 | 04:40 AM
mendon99's Avatar
tastey wheat
molex plug in the door jam?
Old Aug 23, 2007 | 07:05 AM
mach999's Avatar
what molex?
Yeah the white plastic molex housing where the wires run from the car to the door. Did you drill a hole in this or did you just use the rubber housing to run the speaker wire to the door bypassing the molex? I guess I need to take a picture to make more sense of this. Sorry for the confusion.
Old Aug 23, 2007 | 07:14 AM
mendon99's Avatar
tastey wheat
drill a hole in the plug. its a pain in the @ss, but it can be done and is the right way to do it if you're running new wires.
You could also run 9-wire if you prefer.
Old Aug 23, 2007 | 09:12 AM
mach999's Avatar
That's what I was thinking. I don't think there is any room on the molex plug, so do I drill out where the old speakers wires went? God I'm so confused.
Old Aug 23, 2007 | 09:26 AM
mendon99's Avatar
tastey wheat
there is.. i dont have a 5th gen, someone who does has some picutres somehwere, they'll hopefully post them up
theres a space there somewhere Ive had to drill them out before for lines for door locks (alarm install)
Old Aug 23, 2007 | 12:52 PM
i just used the rubber housing. i didn't need to drill any holes. i just had a friend keep the grommet straight, and i pulled the wires through it. i don't recall a white plastic molex housing actually on my 6th gen.
Old Aug 23, 2007 | 01:06 PM
mendon99's Avatar
tastey wheat
may only be in the 5ths, havent checked the 6ths
Old Aug 23, 2007 | 07:41 PM
mach999's Avatar
Here is a pic of what I'm talking about. Behind the black housing in the middle of the pic is a large oval piece of white molex that houses all of the wires that run to the door. After looking at it, I noticed there was no room to run new speaker wires. Any ideas welcome. I apologize again to the OP, I've totally jacked your thread.
Old Aug 23, 2007 | 07:46 PM
yeah my grommet looks like that. i just pulled out both ends and snaked the wires through. i snaked the wires into the kick panel, through the hole and then through the grommet. it was a pain in the ****, but doable.
as for the molex...don't remeber if i have one. i'll check tomorrow and snap some pics.
Old Aug 23, 2007 | 09:29 PM
viperxiv's Avatar
Here is a pic of what I'm talking about. Behind the black housing in the middle of the pic is a large oval piece of white molex that houses all of the wires that run to the door. ..
If you are talking about the same piece I am, you can create an opening by sticking your finger near the bottom and peeling it back. It's very snug and holds the wires.
Don't drill anything it's not necessary.
Old Sep 6, 2007 | 07:58 PM
wunluvbo0mr's Avatar
i'm trying to replace my front door speakers as we speak...only problem is that the stock speaker and the white piece (black piece on my 03) that screws to the door does not come apart, so i have no way of screwing the new speaker onto the door. anyone have experience with this???
Old Sep 6, 2007 | 08:08 PM
mach999's Avatar
You'll have to either cut out the speaker that's attached to the black mounting ring or buy/make some rings.
Old Sep 7, 2007 | 02:55 PM
thanks man....sounds like a biotch...kinda wish mine just had 3 screws
Old Sep 7, 2007 | 10:06 PM
filtor1's Avatar
I just drilled. Muuuuch easier in my opinion. Quicker too. Took 10 minutes to wire up both sides.
Old Sep 9, 2007 | 02:00 PM
01SilverMaxima's Avatar
Ok ive been on this site for hours on end and ive probably overlooked what i need, or im just stupid. I want to install my system in my 01 se(just got it 3 days ago) the cheapest way possible. I have all the amps(MRV-F407 & 2 MRV-t757) and speakers(2 sets of Boston 6.5LF, 2 12" Boston subs), and old eclipse CD5442 HU. I would like to keep the steering whell mounted controls, so for now the HU will probably not go in.
I know how to install systems, but you guys definitely know way more about car stereo than i could ever imagine. Should i go out and buy several line output converters, will that even work? Or do i say screw the steering wheel controls, and install the HU and run all new wires?
Any help is greatly appreciated. Thanks
Sorry to jack the thread, i cant post my own thread yet
Old Sep 9, 2007 | 02:52 PM
DOHCtorJT's Avatar
screw the steering wheel controls and wire it up!
Old Sep 9, 2007 | 10:12 PM
Are 1" rings too big? i bought some tonight but havent opened them yet. I have Boston Pro 6.5lfc, which are about 3" deep. I also found 1 set that came with my speakers, they are 1/2" and seem like they will work fine.
I know you guys are preaching sound deadening but i cant afford it yet, do maximas rattle alot?
