sterio problem again
Old Aug 19, 2007 | 07:00 PM
garyrr's Avatar
so i made a post earlier about a sterio problem and today i went out and re grounded the amps cuz my wires looked very bad and one of my friends said that was probably the cause of my sterio issues. well it did fix it but 2 other problems arose after i did.
1) my mono amplifier is in protect mode and i have clue why because before i grounded it it was fine( i added a seperate ground for each amp so could it be the ground is not good enough for the mono amp?)
2) i have a weird whine come from the speakers if the key is on acc or on even if the deck is off. i can hear the song but a small whine. also when i have the car running the whine is alot louder and goes up and down with the rev of the engine
also something else weird... when i unplugged all the rcas from the 4 channel amp the right side front speaker still had the minor whine in it
set up
all aftermarket speakers with 1 4 channel amp for the speakers and a mono amp for the subwoofer amp and subwoofer. i have 3 sets of rcas running from the deck ( 2 to the 4 channel, and 1 to the mono)
if anyone could help it would be very appreciated cuz i am lost without my music
Old Aug 20, 2007 | 04:56 AM
nismos14's Avatar
§è~® f®ÈÄk
If the whine is still there with the rca's not connected, i bet its that amp thats introducing the noise into the system.
Old Aug 20, 2007 | 09:05 AM
garyrr's Avatar
which amp?
because the one that is in protect mode had nothing to do with the speakers only the subwoofer
Old Aug 20, 2007 | 11:21 AM
nismos14's Avatar
§è~® f®ÈÄk
The one thats powering that speaker that still whines with no rca's in.
Old Aug 20, 2007 | 11:25 AM
garyrr's Avatar
is it the actual amp or the ground or power to it?
i just went out and changed the ground to the strut bolt in the rear. it now whines only in the on poition and while running but not in the acc position:S
Old Aug 20, 2007 | 07:29 PM
maxgtr2000's Avatar
KH3 by popular demand
Sounds like the amp, also strut bolt in the rear the area has to be sanded down pretty good to get a good ground. It makes me think the amp because no signal was going to it and it was still whining. Google "muting plugs" and try that method to be sure.
Old Aug 22, 2007 | 05:58 PM
garyrr's Avatar
ok well i fixed my mono amp being in protect mode but i still have the loud whine
in the acc poition there is a small crackle
in the on poition -a steady whine
in key on engine running- a louder whine that raises with the rpm
now if i take the rca's out there is no noise. if i turn the gain up and down the noise also goes up and down. i tried running a ground straight o my battery and the problem still exists so its not my ground
posible problems i see are
bad rca's
bad amp
problem with the power wire( too close to rca's or speaker)
Old Aug 22, 2007 | 06:34 PM
nismos14's Avatar
§è~® f®ÈÄk
BTW, it's stereo, not sterio.
Old Aug 22, 2007 | 06:37 PM
garyrr's Avatar
that helps alot :|
Old Aug 22, 2007 | 06:55 PM
nismos14's Avatar
§è~® f®ÈÄk
Gain up and down without the rca's connected, causes it to whine more?
Old Aug 22, 2007 | 07:51 PM
garyrr's Avatar
with rca's conected*
Old Aug 23, 2007 | 05:13 AM
nismos14's Avatar
§è~® f®ÈÄk
Ok try it with the rca's disconnected.
Did you try re-grounding and consider replacing rca's?
Old Aug 23, 2007 | 08:56 AM
garyrr's Avatar
with the rca's diconected no sound comes through with gain up or down
i was thinking of running a better set of rca's because the ones i bought are mediocre( not realy cheepos but not top of the line either). i also heard about grounding the rca's to the deck for pioneer units so im going to try thats tonight and if that doesnt work ill try new rca's.
also would anyone recomend using a rca filter. my buddy told me about those a while back when he had this problem with the exact same deck and sub but diff amp and speakers and it worked for him
Old Aug 23, 2007 | 10:11 AM
nismos14's Avatar
§è~® f®ÈÄk
Ya those might work.
Old Aug 23, 2007 | 04:59 PM
garyrr's Avatar
ok so i grounded the rcas to the deck and most of the noise is gone.. the whine is fully gone but still a small crackle in the background and when i turn my car off my mid speakers makes a little noise but i can deal with those so problem fixed i geuss:P
Old Aug 28, 2007 | 12:22 AM
joepino's Avatar
if you had to ground your rcas to your deck then your deck is definitly bad. i cam across this problem before in an intergra and the guy bought a new head unit and it went away. no crackle and no whine. bu tsoon the rcas wont work at all
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
