Need audio help.
Old Aug 25, 2001 | 09:58 AM
Canuck's Avatar
I was having trouble with my Passenger front speaker poping in and out and occationaling just popping, so I switched it with the passenger rear speaker which was working fine, now both speakers are poping like the front was before. Is this a speaker problem or an amp problem?
Old Aug 25, 2001 | 12:42 PM
maximadave's Avatar
detailerdaveb@gmail.com
Check your speaker leads from the amp to the speaker and if thats not it have your amp bench tested...
Maximadave
Old Aug 26, 2001 | 02:20 PM
Canuck's Avatar
I checked the speaker wire, and it was ok, so does this mean that I will need a new amp?
Old Aug 26, 2001 | 03:13 PM
maximadave's Avatar
Maybe...maybe not...have your amp bench tested at a local reputable car audio shop to see if all channels play.
Maximadave
Old Aug 28, 2001 | 01:21 AM
TurDz's Avatar
My friend had that popping problem. Most likely, it is a bad ground. Re-check your ground wires, strip paint in that area if you haven't yet.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Taino14
Sep 24, 2015 02:51 PM
