i want to replace the 8" bose sub,??
Old Sep 8, 2001 | 09:28 PM
victor's Avatar
i just got some extra dough, and i want to change up my sub. i have an amp laying around the house, so i won't have to buy another.
i have a 2k1 SE, with the upgraded bose system. is it possible for me to switch the sub out and install another sub with my amp??? if i can, do i just tap the signal, like i've been reading?? any help is appreciated. thanks.
Old Sep 8, 2001 | 09:37 PM
max'n out's Avatar
you can swap them out,but your gonna need to find an 8 that will work in an infinite baffle configuration. Or build a sealed enclosure along the deck for your upgraded sub.
Old Sep 9, 2001 | 06:17 AM
victor's Avatar
what i had planned was maybe singal 12", and then build a sealed box to spec and face the sub up towards the hole in the rear deck (the place where the eight would have been)so i should not get any rattle from the deck at all.
but what about the swap out, do i need anything extra besides my amp and sub to do it?? i've done a complete system set-up myself before, it's just this Bose thing is trickier or so i hear.
Old Sep 9, 2001 | 11:48 AM
max'n out's Avatar
If you are changing it for sq purpose then you woun't get rattle, but if your a basshead then the 12 will rattle the deck some it is a nissan after all not a benz. What you can do is dampen it and then get the underdeck cover nissan offers to make it look nice. I would suggest upgradeing all the wireing and not using the harness from the bose amp. You can use nissans wireing but I woun't suggest it. IT's always better to upgrade. Alot may depend on the amp and the ohm load your gonna make it run at. If it's a crappy amp then you can get away with using nissans stuff if its a high output amp then upgrade the wiring.
Old Sep 10, 2001 | 08:06 AM
ny96max's Avatar
If you want to keep the 8"sub in the rear deck then id highly reccomend Pioneers ts-w203f 8" free air sub(titanium grey cone). Even though these are last years models you should still be able to get them. These subs work very well with low power systems and should pound with what you have. Also you may want to use some dynamat on the rear deck to help with some new rattles that may spring up.
Anthony
Old Sep 10, 2001 | 11:05 AM
victor's Avatar
thanks for the replies guys.
the amp i plan on running pushes 500 watts x 1 bridged at 4ohms.
i think i'll have to change the wiring. if i can find an 8" that can handle the power i might just switch the 8"s and re-inforce the deck.
it'll be cheaper than buying MDF to make a box, plus i'll still have my space.
the problem is finding an 8 that won't bust.
Old Sep 10, 2001 | 08:34 PM
max'n out's Avatar
What is the amp??? I find it hard to beleive it pushes 500x1 at 4 ohm mono. DOn't be fooled alot of amps are way way way way overrated in power.
Old Sep 10, 2001 | 10:11 PM
victor's Avatar
yeah, it might be overrated but that's what it's rated at. it's a phoenix gold.
MikesChevelle
Nov 23, 2024 11:17 AM
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
cruce91
Sep 20, 2015 10:23 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
