2001 SE with Bose
Old Sep 14, 2001 | 11:25 AM
solfide's Avatar
I have a 2001 with bose system. the system stinks. the factory sub buzzes and the speakers don't get loud. I want to rip it out and completely replace it. I was wondering if anyone knows how or has info on how to install new faceplate, speakers, amp and sub as well as how to rip out the old stuff. do i need to rewire?
thanks
Old Sep 14, 2001 | 12:55 PM
Critical's Avatar
Uhm
yes?
^_^
Old Sep 14, 2001 | 01:48 PM
Maximum Velocity's Avatar
thanks
Yes, you would need a new faceplate, since you're probaby getting a new HU. And you would need to rewire since each speaker is individually amplifiedl. I was talking to a friend that installs stereos, and he said it's a pain cause you have to take everything apart. I'm thinking about doing it, but probably not in the near future. If you do get it done, then good luck and post here to let us know how it goes.
Old Sep 20, 2001 | 08:54 AM
punkrawk2001's Avatar
Steering Wheel Controls
How are you going to wire the steering wheel controls? I haven't found anybody who can do it? I would like to replace my stock stereo (2001 SE) but if I replace the head unit then I would have useless steering wheel controls.
Old Sep 20, 2001 | 10:21 AM
2000MaximaSE's Avatar
The speakers arent indivdualy amplified... the head sends 4 signals back to the main amp in the trunk and from there goes to each speaker... Mine is completly rewired with a stock head. I may do some more work though including new amps and a line driver... Assuming a get the new job....
Adam
Old Sep 20, 2001 | 07:41 PM
Adam
Really??? They aren't individually amplified? Hmm, my bad then. I was always told that they were. And where's the main amp in the trunk? I know that there is an 80 watt amp under the rear deck for the woofer, but I don't know where the other one is. I wired a CD changer to the HU, and took apart the trunk, but didn't see it.
Old Sep 20, 2001 | 11:32 PM
There is indeed an amp back there but thats the main amp for the speakers. The sub has its own crossover and amp built right into itself..
Adam
Old Sep 24, 2001 | 01:18 PM
srbarnes4ever's Avatar
Re: Steering Wheel Controls
I was quoted by my local autosound dealer -- who by the way has had a couple of installs in Autosound and CAE mag -- that there is a $90 relay of some type that can be installed to run an aftermarket unit (must have IR remote) through the steering wheel controls...I plan to have them install my Eclipse 5504 in my 2K1 SE so I'll let you know if it works....
Old Sep 24, 2001 | 01:45 PM
Re: Re: Steering Wheel Controls
srbarnes4ever-
I would REALLY appreciate that. Nobody here knows what to do with it. Thanks!
-David
punkrawk2001@hotmail.com
Old Sep 25, 2001 | 08:33 AM
Re: Re: Re: Steering Wheel Controls
srbarnes4ever-
-David
I'll let you know as soon as I can get over and get an install!
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Tmax78
Sep 25, 2015 09:07 PM
