Radio problem
Old Sep 20, 2007 | 08:24 AM
Quickywd01's Avatar
Radio problem
Last night my subwoofer just stopped working. Whats weird is that when I turn off the radio and turn it back on (no matter how slow or fast) the sub will work for like 10 seconds and then "turn off". I opened my trunk and the blue light on my alpine mrp-m450 was on. I just tried to mess with it; I checked the power cable at both ends, ground, sub to amp and it was all good. Anyone have any idea what's happening? The sub is a pioneer ts-w30m so the amp should have enough power for it. Any help is appreciated.
Old Sep 20, 2007 | 09:05 AM
MissingNAxion's Avatar
Noob wanting more
i dont think you ARE getting enough power or also maybe it is a short. check the line again for any openings as well.
Old Sep 20, 2007 | 09:30 AM
nismos14's Avatar
§è~® f®ÈÄk
Why did you make the same exact thraed with a different title?
Old Sep 20, 2007 | 09:36 AM
Quickywd01's Avatar
What do you mean by not getting enough power? The sub is rated at 150w rms if I remember correctly and I the amp can push 220w at 4ohms, which the sub is. What's weird is that it works when I first turn on the radio for a few seconds and then stops.
Old Sep 20, 2007 | 10:01 AM
internetautomar's Avatar
mod or sell?
if the amp is overheating or not getting enough power (voltage / amperage) it will shut itself off to protect itself.
Old Sep 20, 2007 | 03:25 PM
Quickywd01's Avatar
It worked fine for about three weeks. The amp has plenty of breathing room in the trunk. That's why I'm stumped. I really don't know what to do. lol
Old Sep 20, 2007 | 04:57 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
disconnect the sub from the amp and turn on the system and give it some volume. if the amp still clips, it's not the sub.
Old Sep 22, 2007 | 09:16 AM
Quickywd01's Avatar
If I disconnect the sub from the amp how will I know if it is working or not? More details: I checked all the connections yesterday including the headunit. Everything looks good. The sub works until I turn the volume above 25 or so. If I leave it at 25 it plays. I have played it before at the highest volume level which is 62 and it didn't clip. I'm a newb at this but I do know my sub is rated at 150w rms. My amp is rated at 220w. I had the gain turned about 65%.
Old Sep 22, 2007 | 09:56 AM
methinks your amp is shot.
Old Sep 22, 2007 | 08:15 PM
Quickywd01's Avatar
Dang. What the heck would have caused this to happen. This stuff is like 3 weeks old.
Old Sep 23, 2007 | 05:26 PM
Quickywd01's Avatar
Is there anything in my setup that would cause the amp to do this? I was thinking about replacing it with the same one.
Old Sep 23, 2007 | 05:45 PM
Quickywd01's Avatar
I have infinity reference 9623i rear speakers http://www.infinitysystems.com/car/p...=US&Region=USA and rockford fosgate p163 front speakers http://www.rockfordfosgate.com/produ...n_US&p_status= a Pioneer ts-w30m sub http://www.pioneerelectronics.com/pn...677103,00.html hooked to an alpine mrp-450 http://www.alpine-usa.com/US-en/prod...model=MRP-M450 and a pionner headunit http://www.pioneerelectronics.com/pn...744290,00.html Is the amp good for this sub?
Old Sep 24, 2007 | 09:25 AM
Quickywd01's Avatar
I connected my friends sony 10" sub to my amp and it works fine. I connected my sub to his amp and it didn't really do anything. I removed the sub from my box and the sub seemed like it smelled a little funny. I think the sub is the problem.
Old Sep 24, 2007 | 09:50 AM
nismos14's Avatar
§è~® f®ÈÄk
Prolly sent a clipped signal to it for too long.
Old Sep 24, 2007 | 01:57 PM
jrpaytonAlpha06's Avatar
Sounds like your voice coils are shot. If you have a warranty, see if you can send it in for repair or replacement.
Old Sep 27, 2007 | 01:43 PM
Quickywd01's Avatar
Even though it's only been used for a few weeks and it was new it was a few years old. I searched a little bit and read about wires coming loose in the speaker. I'm going to go hold the cone with my hand while cranking up the volume and see if I can get it higher than it cuts out at.
DJLAX152
May 4, 2021 11:46 AM
mikeg75
Nov 30, 2015 05:12 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
