Mounting AMP to Sub Box.. Good or Bad?
Old Sep 28, 2007 | 10:43 AM
dejahn23's Avatar
I have the Q-LOGIC sealed/vented single 12" sub box and was just wondering if I mount my amp to that box will it mess up the sound of the box?
I know that this would only make it easier for thieves but not really woried about them.
Old Sep 28, 2007 | 12:33 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
ummm...as long as you don't create air leaks (which you probably won't), you won't mess up the sound of the box.
Old Sep 28, 2007 | 01:14 PM
nismos14's Avatar
§è~® f®ÈÄk
You could destroy the amp though, over time they could rattle internals of the amp. but that's somewhat rare.
Old Sep 28, 2007 | 01:35 PM
PimpCode323's Avatar
Tha Don
yea that happen to my friend it sucked
Old Sep 28, 2007 | 03:09 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
Bad, bad, bad.... for one simple reason. If your box gets stolen they get every thing. Trust me I've been down that road once.
Old Sep 28, 2007 | 04:15 PM
slickrick's Avatar
for ease of install its fine...I did it before but prefer them under the seats.
Old Sep 28, 2007 | 04:23 PM
dejahn23's Avatar
I wanted to do under the seat but I couldnt loosen the seat bolts
Old Sep 28, 2007 | 07:15 PM
slickrick's Avatar
workout more?
Old Sep 28, 2007 | 08:16 PM
AscendantMax's Avatar
it's fine, just mount it to your box.
Old Sep 30, 2007 | 07:04 AM
1996blackmax's Avatar
Originally Posted by slickrick
workout more?
That's what I need to do .
Old Sep 30, 2007 | 10:52 AM
djfrestyl's Avatar
Suspension Yoda
I've run my amp on the back of my box for almost a year now - no problems at all.
Old Oct 3, 2007 | 04:44 PM
Bollwerk's Avatar
If you plan on keeping the amp for a long time, I'd avoid it, because of the slow damage the vibrations will do.
Old Oct 4, 2007 | 09:34 AM
spoink's Avatar
I have mounted my amp to my sub enclosures for over 10 years (using the same amp) and I have never had any issues with the amp from vibrations.
Old Oct 4, 2007 | 10:05 AM
yeah, the amp will still experience vibrations unless its mounted far from the trunk. the amp will be fine.
Old Oct 4, 2007 | 10:15 AM
honor_your_life's Avatar
I would keep them seperate, but you can put it on the box. I've seen alot of set-ups like that. Whatever you think is best. Good luck!
-Ryan
Old Oct 4, 2007 | 07:19 PM
Cliff Clavin's Avatar
Way out West
Pretty much every part of my car vibrates. My amp was built before most of the cars on here were even made and it has been in my trunk with no problems.
My amp is in the trunk (bot not mounted on the enclosure):
Depending on how hard you are pushing the amp and the size of the enclosure, the lack of cooling space might be problem. The previously mentioned ability for thieves to get everything in one big swipe is the other big downfall. I used U-bolts to mount my box to the rear metal bracket for the seat. It cannot be removed without taking out the back seat.
Old Oct 4, 2007 | 07:29 PM
filtor1's Avatar
Both of my amps are way to big for concealed locations. So to the box they have always gone. I do find the screws backed out on occasion, but no issues related to the mounting.
Old Oct 4, 2007 | 07:38 PM
maxedoutboi06's Avatar
I have my amps on a board that was built on the back of my box....had it like that for a long time...but i recently just got 2 CVR 15's....neva had a problem....
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
Abdelrhman
Aug 17, 2015 12:16 PM
laparka66
Aug 6, 2015 09:36 AM
