setting up microvision screen
Old Oct 5, 2007 | 07:32 PM
SDB318's Avatar
hey guys...i just bought a microvision screen and also an alpine dva-9860...i have an alpine cda-9827 in there now...i was just wondering if the wiring harness is the same so it would be a plug and play? and also what else would i need to hook up for the new headunit?
Old Oct 6, 2007 | 02:17 PM
djfrestyl's Avatar
Suspension Yoda
Best way to find out would be to jump back there and check.
Old Oct 6, 2007 | 10:25 PM
2AZN2DMAX's Avatar
Alpine plugs either come in black or a white/clear plug. Keep black plug with black plugs and white with white. I beleive the newer Alpines have black plugs while the older ones have white.
Old Oct 7, 2007 | 08:27 AM
mendon99's Avatar
tastey wheat
just because an old plug is the same color and fits into a newer deck does NOT mean it will work - MAKE SURE you check the wire locations as well.
At some point, Alpine swapped the ground and the constant wire in the same color plugs (and same size/fitting), Ive run into this before.
OP, I can pretty much garanty the 9827 harness will not fit in the 9860.
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
