Need helping ID'ing plugs used for an aftermarket HU
Old Nov 5, 2007 | 07:13 PM
Mugen13's Avatar
I had a Sony headunit installed when I bought my Maxima, but it got stolen. So now i'm in the process of looking for a new headunit but I'm not sure what the these 2 plugs are. So can someone help me ID the big plug and the little one (the first 2 pictures) thats being held? What else do I need to hook up an aftermarket HU?
Also, with the stolen HU, the installer did not hook up the subwoofer and there was NO BASS at all. Is there a way to hook up the BOSE subwoofer to the new headunit?
Old Nov 5, 2007 | 07:20 PM
Pearl96Max's Avatar
I tend to get a bit irritable
The first one ... steering/trip controls.
The second ... looks like most likely an 'adaptor' for former radio. Of less likely - IS the former radios harness.
Old Nov 6, 2007 | 10:03 AM
svojs's Avatar
+1 for post #2.
For subs, use the pre-out of your HU. Just add amps and subs. You are GTG.
Old Nov 6, 2007 | 08:37 PM
Mugen13's Avatar
Originally Posted by svojs
+1 for post #2.
is there a way to hook up the Factory Bose amp/subs (for a 2k2) to the HU so I dont have to buy aftermarket amps/subs?
Old Nov 8, 2007 | 05:26 PM
Mugen13's Avatar
so does anyone know if you can hook up the factory bose subwoofers to an aftermarket hu?
Old Nov 12, 2007 | 11:51 PM
Mugen13's Avatar
bump ttt
Old Nov 16, 2007 | 11:22 AM
anngold's Avatar
I don't know, but I wish you luck on finding out.
Old Nov 20, 2007 | 02:01 PM
ZIPPIN's Avatar
Mauja He Mauja
If you do the wiring correctly, ALL bose speakers should work with your aftermarket HU. Bose speakers 2k2+2k3 will work with aftermarket HU's.
Old Nov 21, 2007 | 04:28 PM
Mugen13's Avatar
the subwoofer doesnt work because the previous installer had cut the AMP wiring but all the other speakers work even with the amp plug disconnected from the amp. If I reconnect all the wiring, will the subwoofer work again?
here are the pictures from what it looks like right now
Old Nov 21, 2007 | 09:03 PM
Pearl96Max's Avatar
WoW hackzorz
*Should* all work again, but who knows what else may have been butchered.
Old Nov 22, 2007 | 05:23 PM
SilverGLE's Avatar
I'm watching you, boy...
Originally Posted by Pearl96Max
WoW hackzorz
Yikes, that's nasty! I agree, no telling what the original "installer" murdered during the process... Let us know how it turns out!
Old Nov 22, 2007 | 07:10 PM
ZIPPIN's Avatar
Mauja He Mauja
Looks pretty nasty. You should take your time using butt connectors. Match the wires and it SHOULD work. I purchased these from Walmart and they worked well.
http://www.crowbarelectricalparts.co...Connectors.htm
If it works out, wrap with electrical tape.
Old Dec 1, 2007 | 08:33 PM
Mugen13's Avatar
So I finally got around to it and everything works!
I just reconnected the wires together and everything works perfectly. The only problem that I had was that the plug almost didnt reach the amp since I had to cut it then connect them back togeter but I just unmounted the wiring from the parts it was connect to in the trunk.
Finkle
Sep 27, 2015 09:53 PM
lowpost99
22
Sep 2, 2015 04:38 PM
lummyrob
Sep 2, 2015 12:31 AM
kirkhilles
Aug 8, 2015 10:53 AM
PhalC1
Aug 5, 2015 02:36 PM
