Replacing Bose System (sorry)
Old Dec 2, 2007 | 07:01 PM
Fang_DH's Avatar
I'm sure you guys are horribly tired of these threads, and i'm terribly sorry to start another, but through about an hour of searching I can't find what I need.
I'm replacing my entire bose system, new pioneer headunit, polk momo speakers (components in the front, but no tweets yet) and running two 12" polk momo subs in the back off a kenwood amp. But what on earth do I do about the wiring back to the bose amp? I really don't want to run new wiring through the car (I don't have the brains or time) but I have no idea if I can just splice them together or what. If someone could point me in the right direction, I would be in your debt. Thanks.
BTW its a 2001
Old Dec 2, 2007 | 07:05 PM
ZIPPIN's Avatar
Mauja He Mauja
get ready...
Old Dec 2, 2007 | 07:06 PM
merlin2375's Avatar
I would start here:
http://forums.maxima.org/showthread.php?t=45746
especially post 23
and don't forget for broken links:
http://forums.maxima.org/showthread.php?t=543973
Old Dec 2, 2007 | 07:16 PM
MaXiM@KiD's Avatar
MaXXiN
If you running an amp i would advise re-wiring..the wires for the bose system are thing and are in no way capable of letting enough juice run though the wires to power that amp and push the subs correctly...where are you located I'm pretty sure theres someone on here that would be able to help you run the wires...I'm not sure if your in NY but if you are I do installs and wouldn't mind helpin a fellow max out
Fang_DH's Avatar
Originally Posted by ZIPPIN
get ready...
I know
Old Dec 2, 2007 | 07:21 PM
Fang_DH's Avatar
Originally Posted by merlin2375
I would start here:
especially post 23
Thanks...I've tried some but apparently missed others. The "oldthread" thing works for some, but I've been having trouble with others. But i'll re-read these, thanks!
Old Dec 2, 2007 | 07:23 PM
Fang_DH's Avatar
The amp is just for the subs and is directly hooked up to the headunit and battery. I'd love to be in new york...but I'm stuck in nebraska where NO one is lol.
Old Dec 2, 2007 | 07:35 PM
irish44j's Avatar
retired moderator
moving to the in-car audio section where people with more knowledge on this issue reside...
Old Dec 2, 2007 | 07:36 PM
Fang_DH's Avatar
Thanks...debated doing that but wasn't sure if it was specific to the 5th enough or not.
Old Dec 3, 2007 | 12:26 PM
nismos14's Avatar
§è~® f®ÈÄk
You can use the bose wires, you just have to find the wiring schematic on the outputs from the bose amp so you can match up the speaker wires. That should be available in any on-line fsm.
Old Dec 3, 2007 | 01:15 PM
kauaiwyatt's Avatar
i am having the same problem. i found the wiring diagram here:
http://www.moodym.com/maxima/audio/m...s/5th-gen.html
do i just connect the input wires with the matching output wires?
for example: "17-B/Y (output Left Rear speaker -)" with "21-B/R (input Left Rear speaker -)"???
Old Dec 3, 2007 | 01:48 PM
ZIPPIN's Avatar
Mauja He Mauja
I suggest you run wiring from the amps to the speakers. Don't use the existing wires, if you are replacing the speakers. Thats what I did in my 00. It will take longer, but will sound better. OEM wires wont do justice to your speakers...Are you planning to use the bose amp for the door speakers?
Take out the seats, lift carpet, run the speaker wires from the amp to the doors. Probably 2 hour job.
Old Dec 3, 2007 | 02:22 PM
kauaiwyatt's Avatar
well, i'm using the existing wires. just trying to bypass the amp. so i've cut the whole amp harness off & now i'm going to connect the matching input & output wires from it. hopefully it works.
does that sound right?
Old Dec 3, 2007 | 04:34 PM
ZIPPIN's Avatar
Mauja He Mauja
You should seriously consider running new wiring. Since you are set on using the OEM, let us know how it works.
Old Dec 4, 2007 | 07:21 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Factual data to support this?
Old Dec 4, 2007 | 01:44 PM
kauaiwyatt's Avatar
ok, here's my situation: i've got a jvc navigation head unit, polk components up front, & polk coaxials in the back. the stereo shop installed it all but did not bypass the bose amp. Thus, the volume is still not loud enough.
How do I bypass the Bose amp?
(yesterday, i tried cutting the amp harness off, & then using the diagram at http://www.moodym.com/maxima/audio/m...s/5th-gen.html
I connected the matching inputs & outputs, but now there is very little sound at all even at volume 50 (& only from the tweeters).
Old Dec 8, 2007 | 12:58 PM
Fang_DH's Avatar
ok so I was working on the wires and I went ahead and cut all them off the connector to the amp, and hooked up the front left speaker ones. I was going to test them, but when I turned on my car my HU wouldn't turn on is there a wire that I cut that would cause this, or do I have to finish hooking them up before it will work? I was thinking maybe the Amp on/off signal one? HU was working when I first installed it. thanks!
Old Dec 8, 2007 | 01:13 PM
ZIPPIN's Avatar
Mauja He Mauja
No. But for what I read:
Stock speaker wires are too thin (20 gauge?)
Why cut wires, especially if you are going to sell the car later? I am glad I did not. I took out my stereo and re-installed the bose.
Old Dec 9, 2007 | 04:49 PM
tunedup's Avatar
hey u wanna sell me your harness that plugs into your sub in the back... mines toast.
Old Dec 10, 2007 | 09:18 AM
Fang_DH's Avatar
You talkin the Bose sub harness?
Old Dec 10, 2007 | 07:26 PM
tunedup's Avatar
harness
it doesnt directly plug into the sub... it looks like it plugs into the harness thats coming from the cabin. and from there the harness coming from the cabin is plugged into the sub... it must be some kind of relay.
leave me a msg if u can sell me that
joeytdot@hotmail.com
MikesChevelle
Nov 23, 2024 11:17 AM
rbuswell
Nov 17, 2016 04:54 AM
melteye
May 16, 2016 12:02 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
