My sub stopped working after i installed my new deck
Old Dec 3, 2007 | 06:27 PM
imported_D_Roc's Avatar
posted on the audio forum but no luck, i threw my bose away and installed a new flipout everything is workng good except the subwoofer(stock) won't work any more, i used the special harness (didn use the speaker wire used the amp outputs) the harness had total 4 RCA plugs which is for front and rear left and right and thats all the wires left any idea why the sub won't work i need the sub bad.
Old Dec 4, 2007 | 12:08 AM
maxgtr2000's Avatar
KH3 by popular demand
Is the amp for the sub getting the remote signal from the new hu?
Old Feb 1, 2008 | 09:49 AM
JoshP2002's Avatar
There should be a blue wire on both the harness and the deck, you will have to connect that to turn on that amp remotely. It should derive its signal from the signals given off by the speakers as well.
Old Feb 3, 2008 | 12:51 PM
khemraj1999's Avatar
the stock subs need power to turn on, maybe the harness u got bypass the subs for aftermarket speakers?
Old Feb 6, 2008 | 08:00 AM
wgilles's Avatar
Don't know if I'm going the right direct, but do you need to turn on the pre-amps?
jskirwin
Jun 8, 2016 08:49 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
