Double DIN
Old Feb 11, 2008 | 01:14 PM
StillenMax80x20's Avatar
Double DIN
I have done my research.
I am pretty sure that if i wanted to add a:
http://www.amazon.com/Kenwood-DNX710.../dp/B000NWZPTQ
to a Bose system in a 2000 SE, I would need something like this
http://www.courtesyparts.com/Merchan...de=68750-VENTC
Plus many other things (i.e. replacement speakers, lots of time and wiring)
My questions to you all are:
-Am I missing something?
-Will everything fit right?
and
Is there a cheaper source for the vent assembly?
TIA
akap
Old Feb 11, 2008 | 01:58 PM
Bborges's Avatar
I had to buy the GXE kit as well.. that thing is damn expensive... but it fits very nicely though I still have a gap at the bottom of my new HU (which I plan on fixinf with weatherstripping).
I think you covered it all if you are planning to strip out the Bose system. I left the amp + speakers and only replaced the HU and it was already a HUGE difference... I also have the 2K Bose system.
Old Feb 11, 2008 | 06:09 PM
JAMAICANLOVRBOY's Avatar
i have a 98 and i have a pioneer D2 double din, with no gap at all, and my friend has a 02 with double din also, no gap, and he didnt buy anything extra, jus the radio, and we put it in. only problem he has is the because of the design of the gen 5 dash (the slope design), u kinda need a radio with the tilt forward feature so u can view it better. other than that, it works great.
Old Feb 16, 2008 | 03:25 PM
madmax2002's Avatar
You will need a Bose adapter piece. It's not absolutely needed, but for the volume to work properly you might consider it. PAC makes a pretty good adapter.
Old Feb 18, 2008 | 06:50 AM
'02_EMILBUS's Avatar
that PAC adapter is for an upgraded HU with stock Bose speakers correct?? plug and play?
What is needed to keep the steering wheel controls operable also??
Old Feb 18, 2008 | 07:17 AM
ICEMAN76's Avatar
You need the Pac steering wheel cotrol adapter. Crutchfield has it: http://www.crutchfield.com/App/Produ...&tp=3405&avf=N
Old Feb 18, 2008 | 07:26 AM
Thanks.
So does one need two separate adapters... 1 for the steering wheel controls and another to keep the stock BOSE speakers w/ aftermarket HU??
Old Feb 18, 2008 | 06:04 PM
ICEMAN76's Avatar
Don't know off the top of my head, but more than likely you will. Someone correct me if I'm wrong.
worldwiderecognized
Sep 30, 2015 01:16 PM
ivorton23
Sep 28, 2015 09:08 PM
Socalstillen
Sep 26, 2015 12:01 PM
BrandonCause
Sep 20, 2015 10:20 PM
