Speed Sensor Cable
Speed Sensor Cable
Im trying to install the new Eclipse AVN2210p MKll navigation system and I am wondering if anyone know where the speed sensor cable is located at on a 2000 Maxima SE. Any help would be appreciated. Thanks guys.
Not sure how much different the 2000 is from the 1999, but I had to tap into the cable behind my instrument cluster. I don't recall the color of the cable though. I'm sure someone like Don can tell you though.
I appreciate the info. I just enden up getting the pioneer avic d3 installed. thanks again.
Well, there are 2 wires behind the instument cluster that are pink with a blue stripe. 1 plugs in behind the temp guage, and the other plugs in behind the tach. I dont see any that plug in behind the speedometer, which is where i would think it would plug in at.
You may want to search around the internet for a Field Service Manual PDF for your car. That is where I got the info for my '99 Maxima.
From my FSM:
The vehicle speed sensor provides a voltage signal to the combination meter for the speedometer. The voltage signal is sent
* to combination meter terminals (2) and (4) for the speedometer
* from terminals (1) and (2) of the vehicle speed sensor.
The speedometer converts the voltage into the vehicle speed displayed.
Then I look at the wiring diagram for the combination meter and I see 2 wires coming from the VSS to the combination meter. They are BR/W (Brown with White stripe) and LG/B (Light Green with Black stripe), but I also see another wire output that is P/L (Pink with Blue stripe, as mentioned above) that says it goes "To EC-VSS, AT-A/T, EL-ASCD, HA-A/C,A" - so naturally I am confused.
So if P/L is the wire to tap into, what are the BR/W and LG/B wires for? I feel like such a n00b.
From my FSM:
incase anybody is wonderin the pioneer d3 will work with out tapping into the VSS however if u do tap inot it u get a host of features such as REAL time tracking
i tapped mine in my 07 maxima se non bose, its behind the instrument cluster, pin 26 on the harness, the wire is brown. once again i highly recommend if u have the d3 u do this simple procedure to benefit from all the avic's cool features. but its no required for the nav to work, just makes it extremely accurate
I tapped into the pink/blue wire that I saw coming from behind the Gauges in my 1999 Max. However, when I was driving in a car garage yesterday, I was notified that GPS lost its signal. It didnt show me moving, even though I was driving through the garage. Anyone know what happened?
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
sdotcarter
Sep 2, 2015 09:53 PM
was hoping it would have to be done...since he's usually the one with the smart remarks....he is failing as of LATE...Must be getting old.
