Need help picking an amp.
Old Oct 29, 2001 | 11:33 AM
Canuck's Avatar
I need a 2 channel amp to power my front 6.5 eclipse point source. I am thinking something around a 200 watt amp. I would like something that gives good sound quality, and is reliable. I am on a budget so as cheap as possible without serious comprimise would be helpful.
Old Oct 29, 2001 | 11:38 AM
maximadave's Avatar
detailerdaveb@gmail.com
What price are you looking at?
Alpine MRPF200
40 watts by 4
built in x-over
retail $200.00
Maximadave
www.alpine1.com
Old Oct 29, 2001 | 11:40 AM
Canuck's Avatar
Alpine MRPF200
40 watts by 4
built in x-over
retail $200.00
Maximadave
www.alpine1.com
Thats right in my price range, but I only need a 2 channel. Price is really dependent on the amp, right now I have a RF 200 a4 but it doesn't have the quality I want.
Old Oct 29, 2001 | 11:55 AM
maximadave's Avatar
Alpine MRPT130 $129.99
2-channel
40X2
Maximadave
Old Oct 29, 2001 | 12:01 PM
Canuck's Avatar
2-channel
40X2
Maximadave
I would like to go with a little more power closer to 100X2 rms.
Old Oct 29, 2001 | 12:07 PM
maximadave's Avatar
I have the Point Source as well and only running 75X4 JL amp and the amp is barely cranked up. The speakers only handle 50 watts rms. Why do you want so much power? The Eclipse Point Source are pretty effecient...
Maximadave
Old Oct 29, 2001 | 12:15 PM
Canuck's Avatar
Maximadave
A friend how works at the store where I got the pnt sources tod me I should run higher, or I won't get the sound I want. So you think 40 a side is enough? I guess I could go with the MRPT130. Since my rear speakers (nakamichi) are running off the headunit.
Old Oct 29, 2001 | 12:22 PM
maximadave's Avatar
I would actually run both your Nakamichi's and your Eclipse's off a 4 channel amp instead...40 watts is good power for the Point Source.
Maximadave
Old Oct 29, 2001 | 12:32 PM
Canuck's Avatar
Maximadave
Thanks for all the help, I ordered the mrpf200, for 149, and will power all 4 speakers. This was a lot less than I had expected to spend. You saved me a bundle.
Old Oct 29, 2001 | 12:37 PM
maximadave's Avatar
Old Oct 29, 2001 | 05:18 PM
ny96max's Avatar
id be careful on what you feed those speakers. I just recently took them out of my car cause they cannot handle high power well at all! a solid 50x2 rms amp would be more than enough for them!
goodluck
Ant
Old Nov 1, 2001 | 09:26 AM
abnorm's Avatar
You got Nakamichi speakers too? What kind do you have? Coaxials or components? What do you think of them?
Old Nov 1, 2001 | 12:17 PM
Canuck's Avatar
They are the components. They sound great, but they don't hold up to well. I pulled the front set because they went bad on me. All it took was the change in humidity from houston to denver to kill them
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
maxima-junky
Oct 7, 2015 06:13 PM
REDinLV
Sep 28, 2015 12:31 AM
Pied
Sep 26, 2015 03:29 PM
