5th gen: AMP power wire, WHERE???
Please help me out, i am trying to run my power wire from the battery to the trunk, and i can figure out for the life of me where can i get it though the firewall ???? i looked everywhere and there is no hole.
Take off the driver front wheel (after you have jacked it up of course) and take off the fender liner. You should see a wiring harness that you can follow from the engine bay to the interior.
the hole im talking about is when u remove the fenderwell trim, the engine harness goes into it and next to it the hood release cable is also.
I found the hood release cable on the inside, but the engine harness wasnt next to it.
You can go that way...or you can use a drill and a unibit to drill the correct size hole through the firewall. thats what I did - not too difficult. just surround it with putty or a grommet when its all in place.
there are also already some holes that run other wires and have a rubber grommet. you can cut a bigger hole in the grommet and fit your power wire
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
