ACC wire in trunk?
Old Apr 4, 2008 | 11:04 AM
BLACKonBLACK98's Avatar
Former Vendor
ACC wire in trunk?
for you electronics gurus: is there a place to tap a switched 12v in the trunk? if not whats the furthest back? 98 maxima btw...
Old Apr 4, 2008 | 12:22 PM
Deckdout2's Avatar
Play with my balls
Normally a hazard/turn signal relay is located in the trunk. It's mounted on the wall between the spare tire well and the rear bumper. You'll have to pull the cover of that back wall off, and it's back there. I had my strobes in my old 4th gen hooked to that relay. When I hit the hazards the strobes came on.
Old Apr 4, 2008 | 12:27 PM
Former Vendor
aren't hazards on a constant 12?
Old Apr 4, 2008 | 01:08 PM
Deckdout2's Avatar
Play with my balls
Not if you pick the switched wire to tap into at the relay. I remember, because when I hooked up my strobes, one of the wires turned them on constantly, and the other turned them on when I hit the hazard button. I think there's another relay for it under the dash which might be linked to the turn signals as well.
The relay in the back I used because when I pressed the button on my keyfob for the car to lock/unlock, it would activate that relay for the turn signals as well, which in turn activated my strobes.
What are you connecting?
Old Apr 4, 2008 | 02:34 PM
Former Vendor
i need a switched 12 for the solenoid to my air compressors. when i say switched i mean an acc wire (hot when key is in ignition) not a wire with a switch. thanks though.
Old Apr 4, 2008 | 07:56 PM
Deckdout2's Avatar
Play with my balls
Ahh, got ya. Will let you know if I remember, come across any.
Old Apr 4, 2008 | 08:19 PM
mendon99's Avatar
tastey wheat
i doubt theres anything back there. just run a line from an accessory wire.
Old Apr 7, 2008 | 06:17 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
about the only thing would be the fuel pump
right unde the seat
Old Apr 8, 2008 | 11:26 AM
Deckdout2's Avatar
Play with my balls
right unde the seat
I can't remember, but I thought the fuel pump activated in the "ON" position?
Old Apr 8, 2008 | 11:54 AM
Fast1one's Avatar
Don't be lazy
J/K
Old Apr 8, 2008 | 12:43 PM
Former Vendor
its not a matter of being lazy... its having the wiring as clean as possible. but i figured out i'm going to need a couple acc points so i'm going to make a terminal block under the dash.
air should be arriving today btw.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
