I am shopping for an amp.
Old Apr 21, 2008 | 07:32 PM
JSMax's Avatar
Sold
and I need help deciding on what to purchase.
here's the requirments. I CANNOT run anymore than 600watts RMS due to the underdrive crank pulley that I have installed in my 1997.
I have polk audio rm6501 components up front rated at 10-100 watts rms with a max of like 300.
For the rears, I will be running polk audio rm651s 55 watts rms max. I have not picked the deck yet, but am really leaning towards the alpine w505 or the eclipse avn 6620. Both have strong points and are killer decks. I like the idea of the portable navi with the alpine, and the dual drives with the 6620. Full ipod video support with the 505.
I believe that I would like to purchase a 5 channel amp for the simplicity of the install. I don't have any sub(s) yet, but I will probably be adding something simple in the future. I am leaning toward the alpine pdx-5.
But, I like the fact that jlaudio rates their power from like 11.0 volts to 14.5. It's a true 75X4. they don't make a 5 channel that I am aware of. I go this way (jl audio slash series 300/4v2) and if I want to add a sub later, I will need to add another amp right?
Any suggestion or insight would be great.
thanks guys and girls.
Old Apr 21, 2008 | 08:04 PM
travmaximas1998's Avatar
if u wanna save room i would go with a 5 channel
and if u use the jl for now with the 4 channels
u will have to later down the road buy a small mono block to run the sub stage
Old Apr 21, 2008 | 08:18 PM
Pearl96Max's Avatar
I tend to get a bit irritable
A beefy 4 channel and run the rears off the deck will work as well. This can run your components off of two and the sub off the remaining. What is your budget?
Eclipse gets my vote.
Old Apr 21, 2008 | 08:19 PM
Pearl96Max's Avatar
Why does it have to be a 'mono amp' ?
What is a 'sub stage' ?
Old Apr 21, 2008 | 08:28 PM
it doesnt have to be a mono and what u said would work just fine
sub stage = the subs he is running/his sub rcas whatever u wanna call it
Old Apr 21, 2008 | 08:34 PM
Pearl96Max's Avatar
Then you can just call it sub(s), no such thing as a 'sub stage'.
Old Apr 21, 2008 | 08:41 PM
well i like sub stage lol
im running a 4channel that has channel 1 and 2 goin to my mids, and 3&4 bridged to my subs, and a 2channel running my tweets
Old Apr 22, 2008 | 06:44 PM
angelmaxima's Avatar
I think your right on. I would go with the JL 4 channel..get your setup and get a 2 channel later for any additions
Old Apr 22, 2008 | 07:24 PM
JSMax's Avatar
Sold
Eclipse for the deck I assume gets your vote for headunit? Why that over the alpine? just looking for opinions.
If I do this, like you described, will I even be able to hear the rear channels? I mean 75 watts true RMS against what 18 for the rears. I understand that the rears are for fill, but I would like to be able to hear them for the soundstage.
how will this workout? Also, I think that I would like to wire it up only one time and not have to mess around with things later on if I decided to add the sub. So many decisions....
As for budget I'm thinking around 400 us for an amp. the jl is on fleabay right now here and the alpine is here . yeah.
Old Apr 22, 2008 | 07:27 PM
JSMax's Avatar
Sold
easy down.... maybe he just invented that term so now it's a new thing.
Old Apr 22, 2008 | 07:54 PM
cfr94's Avatar
I have a Kicker KX550.2 for sale. Not sure if it will work, but let me know if interested.
Specs:
Frequency Response: 20Hz-20kHz, +0, -1dB
Input Sensitivity: High Level 340mV-10V, Low Level 170mV-5V
Signal-to-Noise Ratio: >95dB
Active Crossover: 12dB/octave, variable 50Hz-200Hz, selectable high
pass, low pass, or all pass; KX100.2 high or low fixed at 80Hz
KICKBASS Boost: Variable to +18dB, (KX100.2 variable to +12dB)
centered at 40Hz
Past Output RCAs
Kicker KX 550.2
Power (WATTS/CHANNEL), 2 Ohm Stereo 275 x 2 W
Power (WATTS/CHANNEL), 4 Ohm Bridged Mono 550 W
Dimension A With EndKaps (cm) 57.2 cm
Remote Bass Control: Yes
Fan Cooling: Yes
Old Apr 22, 2008 | 07:57 PM
JSMax's Avatar
Sold
that's only a 2 channel. Not really interested, but maybe someone else would be?
Old Apr 22, 2008 | 08:24 PM
Specs:
centered at 40Hz
Past Output RCAs
Kicker KX 550.2
Fan Cooling: Yes
How much famm???
Old Apr 22, 2008 | 08:46 PM
cfr94's Avatar
Originally Posted by angelmaxima
How much famm???
PM Sent
Old Apr 22, 2008 | 08:53 PM
Pearl96Max's Avatar
How much famm???
Nice 4th gen in your cardomain, who did all the work to it?
Old Apr 22, 2008 | 08:55 PM
Pearl96Max's Avatar
Overall better nav, transport and DA converter.
Old Apr 23, 2008 | 09:31 AM
Dasyce's Avatar
Car looks exactly like Freddy's old Max.
Old Apr 23, 2008 | 08:35 PM
JSMax's Avatar
Sold
and then I found this one
http://www.woofersetc.com/index.cfm?...roduct_ID=5653
what do you guys think?
I'm leaning toward the 5 channel amps due to size and simplicity of install.
Old Apr 23, 2008 | 08:43 PM
It is. That's my cousin. Decided to keep it in the family. That's wasup where you from? holla @ me sometime. Fred got a new toy now lolzz
Old Apr 23, 2008 | 08:53 PM
Pearl96Max's Avatar
My thoughts exactly ! Havent seen Freddie in years.
Old Apr 24, 2008 | 09:55 AM
shyheim07's Avatar
Specs:
centered at 40Hz
Past Output RCAs
Kicker KX 550.2
Fan Cooling: Yes
since when are those fan cooled?
Old Apr 24, 2008 | 05:03 PM
JSMax's Avatar
Sold
if I were to purchase the alpine pdx, what sort or wiring kit should I purchase to go with it?
thanks people.
Old Apr 25, 2008 | 07:22 AM
ElVito1981's Avatar
get an audison! It's Italian--nuff said
Old Apr 25, 2008 | 07:55 AM
BLACKonBLACK98's Avatar
Former Vendor
yeah... its also about 4x what he wants to spend.
Old Apr 25, 2008 | 10:08 AM
JSMax's Avatar
Sold
I would rather not blow the whole budget on an amp. That's why I didn't list them in my orginal post. I am familar with audison and hertz, rainbow and some of the other high end product, and although that product is fantastic, it's priced way out of my budget. But, hey, thanks for adding something to this thread and backing it up with an intelligent argument.
Old Apr 30, 2008 | 08:31 AM
ElVito1981's Avatar
anytime
Old May 1, 2008 | 12:04 PM
JPIZZLE's Avatar
Hey MAn
PM White Shadow, He has a set of 403b Extant 3 channel amps brand new for a steal. I would talk to him first before you put out some cash for the PDX stuff. These are pretty good amps and for 300 bucks you cant beat it!
Old May 5, 2008 | 11:39 AM
Reece616's Avatar
If you got an amp for just the front and rear speakers, and decided to add another amp for a sub, you should be able to relatively easily. The amp for the speakers should have RCA outputs which u can connect to the sub amp to send the signal. To get the power to it, just get a distribution block and u can wire it up without taking of trim pieces and pulling up carpet.
Old May 5, 2008 | 01:36 PM
Former Vendor
rca outs are not a standard feature, although fairly common. might want to check the amp specs before you bank on that one.
Old May 6, 2008 | 04:45 AM
JSMax's Avatar
Sold
ahhh I didn't know that. Thanks for the tip.
Old May 6, 2008 | 07:11 AM
Reece616's Avatar
+1 what he said haha
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
RealityCheck
Oct 2, 2015 06:34 PM
Sep 27, 2015 08:37 AM
foodmanry
Sep 24, 2015 12:02 PM
Max8
Sep 22, 2015 02:53 PM
