Where could I mount two amps in a 4th gen?
Old Nov 1, 2001 | 01:28 PM
blizz20oma's Avatar
I'm so hood
I'm trying to figure out where I could mount two amps in the trunk of my 4th gen. I asked this before, but I think everyone responded that they mount their amps to their sub box (in the traditional sense of mounting to sub boxes, blech). Anyone have any other good mount points? The trunk doesn't seem very friendly in that aspect.
If I have to, I might mount them to my box, but I'd probably put two extra blocks of wood on the sides of the box to screw the amps into, and have the extra blocks stabilized on the sub box by means of adhesive and not extra screws into the sub box. Extra screws through the sub box is what I'm trying to avoid. Anyone mount to their sub box without putting extra screws directly through the sub box itself?
Old Nov 1, 2001 | 03:30 PM
Whitemax's Avatar
Disco Biscuit
Well, I mounted my 2 on either side of the trunk access hole like this:
Old Nov 1, 2001 | 07:57 PM
97GreenMax's Avatar
I mounted mine on one side of the back trunk wall.
Old Nov 1, 2001 | 11:26 PM
SWEETSOUND2001's Avatar
http://images.cardomain.com/installs...7_179_full.jpg
Old Nov 2, 2001 | 02:29 PM
OgreDave's Avatar
you couldnt get my ppi 4800 to fit like that
Old Nov 2, 2001 | 07:18 PM
SighMax's Avatar
Maxima Enthusiast
Re: Where could I mount two amps in a 4th gen?
Here's a link to my 2 PPI a600 on either side of the access home.
Click Here for 2 PPI A600
Old Nov 4, 2001 | 10:52 PM
Xmax's Avatar
This may sound very odd, but if your box has that carpet felt, try velcroing your amp to it. Your amp shouldn't move at all if you secure it well enough. And you don't have to worry about drilling a screw into your box. This is only recomended if you place your amp on top of the box, you should test how much velcro you need if you want to mount it on the side or something. Hope this helps a bit.
Old Nov 4, 2001 | 11:10 PM
Shadow's Avatar
That velcro actually works pretty good. I used it on a small MTX amp a while back. The new system I'm working on will have 1 amp mounted on the passenger side wall on a plexi rack, one amp mounted in the floor (it's too d@mn big to put anywhere else) and the nitrous bottle mounted on the drivers side wall on a custom rack. Probably not going to be too much trunk space left though.
Old Nov 5, 2001 | 06:41 PM
Gunner's Avatar
sweetsound: how did you mount your amps there? drill holes? i have a fifth gen an i was thinking about using the same mounting spots but dont really want to drill into the floor..
Old Nov 5, 2001 | 06:46 PM
jimmijam's Avatar
dude, just build an amp rack out of some fiberboard or something. It's a lot easier to access the amps when you have a project to work on and you can design the layout without having to work around the backseat.
jimmijam@hotmail.com
Old Nov 5, 2001 | 06:48 PM
Self-drilling screws right into the floor.
Anton
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
