*Can an EXPERT audio guru tell me the specs of this box??*
Old May 23, 2008 | 03:36 PM
PandaXpress's Avatar
Sorry guys, I cant figure out the specs for this box. Please guys. I'm looking at buying a custom built box and these are the measurements...
BOX IS
W 30.5" x H 15.5" x L 16.5"
PORT IS
W 24" x H 14.5" x L 14" (Does the port even make any sense now that i think about it?) how could it be almost the size of the box??
I just need someone to help me out and tell me how many cubic feet the box will have and what will it be tuned at? (BTW its a single chamber Dual 10" sub box, with a square vent)
Ive tried using the guide on 12volt.com and other calculator to figure it out, but I cant figure out what it tunes to and I'm not so sure I should be using a sealed box calculator for the displacement (in cubic feet) for bass reflex.
Old May 23, 2008 | 04:46 PM
Please guys really need to know. Or at least the method for calculating the box specs. Thanks again.
Old May 23, 2008 | 05:58 PM
chinaonnitrous1's Avatar
The port doesn't really factor into the enclosure size.
The cubic foot is just that. Fill it with water if you like and measure that. Its gonna be the same with the port or not.
Old May 23, 2008 | 06:14 PM
k...thank you for that...now what does it end up being tuned to?
I checked the box calculator and got about 3.5cf3
Old May 23, 2008 | 07:01 PM
Oh boy, theres a set of calculations for that one....
port length, diamerter, etc..
Old May 23, 2008 | 09:27 PM
AscendantMax's Avatar
overall dimension: 30.5" x 15.5" x 16.5"
gross box volume: 3.524 sqft
what's your desired tuning frequency and target airspace for the subs?
Old May 24, 2008 | 04:51 PM
travmaximas1998's Avatar
PORT IS
ya with that port we dont have enough info sort of
is that the whole volume?
cuz we need the surface area of the port
Old May 24, 2008 | 06:44 PM
i don't think that's the right port dimension. that is a HUGE port based on those measurements.
Old May 24, 2008 | 11:06 PM
aight guys here are some facts on the HX2 10" (hope you can see)
For a vented enclosure its about 1.0cf3 per sub at 35hz.
Im gonna be running Two 10's at 500 wrms a piece
The specs are probably going to be 30.25 x 12.25 x 16.5 [2.68cf3] (WxHxD) tuned at 38hz
What do you guys think?
Old May 25, 2008 | 10:29 AM
38 hz tune will be too peaky in my opinion, and your low end extension won't be as prominent.
i say aim for 32hz tune. if you're going to do that...try these dimensions:
box size: 30 x 12.25 x 16
gross volume: 2.57 cuft
port width: 2
port height: 10.75
tuning: 32 Hz
port length: 24.335
port disp: .403
net airspacee: 2.06
this will give you close to 1.0 cubes of airspace per sub with a better tuning IMO.
Old May 25, 2008 | 11:54 AM
LOl! Thanks man! So have i convinced you to build it for me?? You havent been on AIM for a while...lol.hit me up!
port width: 2
port height: 10.75
tuning: 32 Hz
port length: 24.335
port disp: .403
net airspacee: 2.06
Old May 25, 2008 | 03:26 PM
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
