Did some deadening and added a temporary amp.....
Old Jul 21, 2008 | 09:08 PM
95maxrider's Avatar
Lightly modded
Well these pictures aren't all from the same day, but now that most of the work is done, I thought I would share. Last year I bought some Hertz speakers from Don along with a 12" DIYMA sub. During the process I a lot of deadening with E-Dead and this stuff called Duct King Insulation. I used the insulation over the E-Dead in some places but also used it alone around the shifter to quiet exhaust noise and in the footwells of the car to quiet road noise. I noticed a huge improvement from the shifter part, not so much from the footwells.
Thankfully, I had Patrick (PHenry) to help me with all of this. He sold me an old Sony amp for $25 to tide me over until I figure out what I want to do. The Sony is powering my sub while my RF 500x is powering my fronts. We figured out one of the channels on the RF is dead, so instead of bridging the front we just didn't hook up the channel that's bad. Patrick also did my big-3 wiring upgrade, which gives me peace of mind, since we decided to remove my capacitor.
Part 1 (E-Dead)
Part 2 (More E-Dead and insulation)
Insulation on inside of front doors to hopefully make a tighter "seal".
E-Dead on the rear deck
Insulation in foot well
Old Jul 21, 2008 | 09:11 PM
95maxrider's Avatar
Lightly modded
One part of the Big 3
My super-baller elite amp setup
The insulation. 15ft^3 for $10 IIRC.
Old Jul 22, 2008 | 09:11 AM
SilverGLE's Avatar
I'm watching you, boy...
How well does that duct insulation work? Looks good! I'd like to deaden the rear deck, but I haven't had the time lately.
Old Jul 22, 2008 | 08:45 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Good job, but lets cover up that hole where the handle and lock bars go. Cover them with 1/4" flex loom, then deaden over it all. Simple trick that has been working for me for years.
Old Jul 23, 2008 | 07:05 PM
phenryiv1's Avatar
Mod her. Ate her.
I was trying despirately to noodle some way to cover in that hole. Leave it to you to figure out what I could not.
I DO have one noteworthy thing to mention...while Nick has in the past been somewhat clueless on how to mod a part of his car , he really has stepped it up. He may give me a lot of credit, and I do give him technical advice, but he did do a LOT of the work on this- removal, install, reassembly, etc. He did a lot more hands-on stuff than any time in the past. I think that I really could have pointed and directed and he could have executed the install as well as I did. Hats off, Nick...
Old Jul 23, 2008 | 07:08 PM
phenryiv1's Avatar
Mod her. Ate her.
As a barrier membrane, it is hard to beat. I blocks and absorbs sounds...it does not deaden them like mass-loading does. It is good becase it is cheap and you can run to Lowes or HD if you run short on it mid-install.
I use aluminized HVAC tape to adhere the edges, and I had great luck with it holding up in my Spec.
Old Jul 23, 2008 | 09:20 PM
95maxrider's Avatar
Lightly modded
lulz....way to call me out
So...it turns out my drivers door has a hard time getting the lock mechanism to lock properly. Feels like there's some obstruction
Old Jul 24, 2008 | 10:52 AM
SilverGLE's Avatar
So basically use it to keep out unwanted sound, like on a door, as opposed to dampening vibrations?
Old Jul 24, 2008 | 12:59 PM
meccanoble's Avatar
Sports Button FTW
waiting for input on this as well . Think i may grab some tomorrow...depending on answer.
Old Jul 24, 2008 | 01:26 PM
SilverGLE's Avatar
^ Heh, I'm not too up-to-date on sound deadening materials, effectivess, and purposes if you can't tell. I'm hoping to stick a free-air sub (Image Dynamics probably) in place of the Bose 8" and probably deaden the rear deck while I'm at it.
Old Jul 24, 2008 | 06:24 PM
phenryiv1's Avatar
Mod her. Ate her.
Yeah- it blocks and absorbs sounds, as opposed to mass-loading, which actually (through preventing reverberations in the first place) prevents sound.
Old Jul 24, 2008 | 07:15 PM
meccanoble's Avatar
Sports Button FTW
prevents sound? So you are saying this will keep volume and reduce vibration compared to multi layer deadening that reduces sound as well? Where are the ideal places to use this? And are you saying this works better for sound deadening than things such as cascade, dynamat, edead, etc? or more or less work better if you are planning to put multiple layers?
sorry im a deadening retard...but you have my attention
Old Jul 24, 2008 | 09:00 PM
Pearl96Max's Avatar
No.
Now read ... www.cascadeaudio.com
Old Jul 24, 2008 | 09:01 PM
Dave Holmes's Avatar
Looks good. Between the E-Dead and duct insulation, which do you think is more effective? Where did you find the E-Dead? I'm assuming it is similar to Dynamat and such (a heavy "tar" type sound dampener).
Interesting that insulating under your shifter was more effective than doing the footwells.
Dave
Old Jul 24, 2008 | 09:09 PM
Pearl96Max's Avatar
You can find E-dud at your local HD or Lowes, it is however in it's original form and does not have 'name branding' on it.
Dave
Quite common as that is the tranny tunnel and a major culprit of more than just road noise.
Old Jul 25, 2008 | 09:18 AM
95maxrider's Avatar
Lightly modded
Don't knock the E-Dead. As long as it's heated up and the surface is clean it sticks and stays as well as anything else. I believe this only applies to the V.2 stuff though, not so sure about the earlier versions.
Yeah, I had removed my heat shield so it was a straight shot to the ground/exhaust. It's probably different if you have an auto though.
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Dec 12, 2015 09:39 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
