my sub stopped working
Old Aug 1, 2008 | 08:01 PM
WielkiWaac's Avatar
MaximaDriver
make a story short.
today my box (2 speakers) stopped working. It has power, all fuses OK, amp does not show any errors, double checked all connections. I didnt play loud so i dont think that i burned both speakers.
Any ideas?
Old Aug 1, 2008 | 08:10 PM
metallic97gxe's Avatar
Master Will
you get no sound from the subs at all? is the head unit putting out?
Old Aug 1, 2008 | 08:19 PM
WielkiWaac's Avatar
MaximaDriver
no sound at all, and one more think. when i hit a little bump i can hear some noise from speakers, not sure if something is short, but i checked everything and found nothing
Old Aug 1, 2008 | 08:25 PM
AscendantMax's Avatar
either bad remote wire connection or the fuse up front under the hood went bad (even though it may look fine, the prongs can become detatched from the end caps)
Old Aug 2, 2008 | 08:33 AM
WielkiWaac's Avatar
MaximaDriver
just came back from my car and found out that fuse in my amp was blown. replaced with new one 20A and that b.... blow out in my hand (radio off). after that disconnected battery and put another fuse, hooked up battery and see that big *** spark. and what? another fuse is blown. WTF??!! checked all connections and did not see any shorts. Now I have no idea what to do with it!!
Old Aug 2, 2008 | 10:19 PM
Drockb418's Avatar
if you have a factory head unit and you bought a high and low converter, check the wires you spliced and make sure it did not cut clean though the wire and...... that way it cuts the power to the factory amp thus causing the speakers to not work.... hope it works!
Old Aug 3, 2008 | 04:04 AM
WielkiWaac's Avatar
MaximaDriver
noo, my amp is fried. saw smoke coming out from it
Old Aug 19, 2008 | 05:40 PM
dreek96max's Avatar
Answer
Are any of the subs playin....or jus one is not.....if one is and the other isn't there is a lil piece of wire inside the sub that connects the positive and negative. I think that wire has came loose and it has to be saudered back on
Old Aug 20, 2008 | 07:54 AM
nismos14's Avatar
§è~® f®ÈÄk
Did you read the thread?
Old Aug 23, 2008 | 07:43 PM
phatryan69's Avatar
tell you what you need to do... get a meter and check and see what ohm your subs are puttin out and if they are blown you have hear kinda like a crunchin sound and you can feel it becuz its hard
Old Aug 31, 2008 | 10:26 AM
angelmaxima's Avatar
Do sub tests and if they are fine i'd go with a new amp... im a short and sweet person tho, cut straight to the solution LOL
Old Sep 6, 2008 | 01:47 PM
BiZzL3's Avatar
mine was doing the same thing but when i hit a bump it made a loud noise....and it ended up being a bad ground....also you cant run the remote or rca wires anywhere near the battery wire...good luck
Old Sep 6, 2008 | 01:53 PM
nismos14's Avatar
§è~® f®ÈÄk
Cotozic
Jun 28, 2017 08:01 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
