New Scosche Dash Kit Info
Old Oct 25, 2008 | 07:38 PM
  #41
Andrew's Avatar
Originally Posted by bkucera
Got my kit and installed it today on my 2002 Maxima SE, and it's not a great match. In low light you can't really tell the difference, but during the day it's pretty obviously a lighter color.
I'd say that croser's pictures show its color accurately though, so did they put different color trim pieces in 2002-2003 Maximas? I have the manual climate control but my vent trim is the same color as the piece below his automatic climate control unit, which you can see in the pictures is much darker than the Scosche dash kit.
It does fit well, yeah the plastic seems flimsy but once it's in there I really doubt it's going to move. If you're worried about it drilling new holes into the OEM metal brackets would probably work.
Pics please?
Old Oct 26, 2008 | 11:48 AM
  #42
bkucera's Avatar
Sometimes it looks the same color, most of the time it doesn't. In direct sunlight it usually looks the same color, and sometimes at dusk it does. All the rest of the time it looks lighter than the rest of the trim.
Old Oct 26, 2008 | 04:21 PM
  #43
Andrew's Avatar
Thank you. It really doesn't look that bad though. Looks good to me! thanks
Old Oct 26, 2008 | 06:05 PM
  #44
bkucera's Avatar
Yeah I'm happy enough with it, just pointing out that it's not a great color match in most lighting conditions if that's really important to anyone.
Old Oct 26, 2008 | 06:39 PM
  #45
Andrew's Avatar
I'd rather pay uner $30.00 for the kit instead of $100+ for the GXE kit.. thats how I look at it.
Old Nov 5, 2008 | 07:06 AM
  #46
odecom5's Avatar
Originally Posted by croser2
Here's pics. The included brackets are plastic BTW, but align perfectly. They seemed flimsy, but once it is all in there, it is pretty solid. I may use them for a template to drill new holes in the stock brackets, but not likely. It all in.
My bluetooth microphone
sorry to bump this thread... looks great! I was wondering how you did the mounting for the bluetooth mic? That's a perfect spot for it. also wondering if anyone knows where i can find this a/c control unit. ebay doesn't have anything that does't look like it was dragged on concrete for 5 hours...
thanks!
Old Nov 5, 2008 | 02:48 PM
  #47
croser2's Avatar
I would try out different mic places first. As some poeple complain about how it sounds. I've been planning on moving it, but am just too lazy.
I just started with a small drill bit and worked my way up. Then I made it slightly too large. I just set the microphone in the hole, added a little silicone, and let it sit til firm.
Old Nov 5, 2008 | 02:58 PM
  #48
Torgus's Avatar
i like running the mic into the a pillar and directional mounting it there that's what i did with my 4th gen. also use a step drill bit to make the whole if you have one. or as the op mentioned use larger and larger bits.
Old Nov 6, 2008 | 06:13 AM
  #49
odecom5's Avatar
i just realized that this dash kit wouldn't work for me. my a/c and stereo trim (stock nav) are one piece... is there a kit available for that setup?
Old Nov 6, 2008 | 09:34 PM
  #50
hi-tek22's Avatar
which IN DASH kit do you all suggest to use any way...THE OEM one for the stock Navi?
Old Nov 7, 2008 | 08:27 AM
  #51
odecom5's Avatar
too big for normal double din stereos. you'll have about a 1/2" gap. That's what I have and I am looking for possible solutions..
Old Dec 9, 2008 | 08:55 AM
  #52
Jreed2008's Avatar
Thank god I found this thread i was actually considering spending the money on a gxe kit and I have went thru two NN1494B Kits so I hope this new one does the trick
Old Dec 9, 2008 | 11:14 AM
  #53
stronium_95se's Avatar
I just installed the scosche kit with the pioneer f90bt the other day, everything looks good!
Old Dec 10, 2008 | 02:38 PM
  #54
croser2's Avatar
^^Thats why I made it.
Old Dec 21, 2008 | 04:37 PM
  #55
Emaximus's Avatar
I just got the scosche also and the color is a bit off. I'm tempted to paint the thing. I'll keep it in until I can find a junk yard GXE double din somewhere. It fits well but I just can't get over the slight color difference.
Old May 24, 2009 | 03:47 PM
  #56
soxruled0's Avatar
so will this kit fit the in a 00 maxima with the bose hu i ordered a double din hu not knowing how much of a pain it would be to find the right kit
Old May 24, 2009 | 03:52 PM
  #57
soxruled0's Avatar
i just recieved this kit and painted it black it matches with the climate control alot better and makes it look like the GXE kit
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
