running 2 separate power cables
Old Aug 28, 2008 | 05:00 AM
Max Noob's Avatar
is it ok to run 2 smaller gauge wires to an amp insted of 1 larger one. for example two 10g wires instead of a single 8G??
Old Aug 28, 2008 | 07:11 AM
BLACKonBLACK98's Avatar
Former Vendor
as long as the wire can handle the amperage then your ok, but it seems like more trouble than its worth.
Old Aug 28, 2008 | 07:34 AM
filtor1's Avatar
I have done it before. Used dual 4gauge b/c we didn't have any more budget for new wire. There will be no issue with doing this.
Old Aug 28, 2008 | 11:44 AM
meccanoble's Avatar
Sports Button FTW
sounds ghetto but i guess it will work.
Old Aug 28, 2008 | 12:47 PM
Max Noob's Avatar
haha.im unemployed right now..so ghetto is all i can do.. . should i use 2 separate 20 amp fuses at the battery side(one on each power wire), lead them both into the external 40 A fuse that came with the amp? i think i can get my hands on a foot or 2 of 8 gauge wire to go from the amp side fuse to the power lead. ill use 8g for the ground also.
Old Aug 28, 2008 | 12:49 PM
nismos14's Avatar
§è~® f®ÈÄk
A 20 on each wire should be fine.
Old Aug 28, 2008 | 01:12 PM
Max Noob's Avatar
thanks for everyone's input.
Old Aug 28, 2008 | 01:33 PM
filtor1's Avatar
No problem. If you want to make it a bit more stealth, you can always loom or tape the two wires. I have done both with excellent results. Not to mention loom is cheap.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
vybz05
Dec 10, 2015 07:38 PM
schmellyfart
Sep 25, 2015 04:47 PM
cruce91
Sep 20, 2015 10:23 AM
