fuse question no tail or engine gauge lights
Old Sep 4, 2008 | 01:06 PM
tbombs32's Avatar
so my entire engine gauge(spedometer tach gas oil), bottom A/C lights and my taillights/license plate lights all went out randomly. i checked most of the fuses and didnt find anythin. anyone know what fuse or the cause of this could be??
Old Sep 7, 2008 | 09:07 AM
djfrestyl's Avatar
Suspension Yoda
It's a fuse, tail lights and gauge lights are on the same circuit. If you didn't find it yet, you're not searching hard enough
Don't forget there's a fuse box under the hood too...
Old Sep 7, 2008 | 09:08 AM
Definitely a blown fuse. Check all your 7.5 fuses carefully.
Old Sep 18, 2008 | 12:00 PM
bambino's Avatar
Haha, that happened to me yesterday night as I was driving back home... My taillights, license plate lights, shifter lights, and stereo lights went out. I know we have 3 fuse boxes? right? One under the steering wheel, one on the engine/hood, but where's the passenger one that I hear people talk about from time to time?
Old Sep 18, 2008 | 12:34 PM
rocklee2029's Avatar
DUDE i have the same exact problem! well in order to fix the taillights look under the hood. theres a fuse box on the drivers side next to the battery and air intake box. there should be a 15amp fuse for TAIL L. thats the one you change out for the taillights/license plate lights/cornering lights. i was able to fix my taillights that way... however still having issues with my gauges, havent had the chance to take it in to get it checked. but hopefully the fuse for the gauges/climate control/gear box is the only problem with those lights... that fuse is a 7.5 amp. the fuse box is under the driver's side dash.. look under INT ILL. that should be the culprit. if the fuse blows again after you put in a fresh one.... i dunno wat to tell ya i have the same prob =/
Old Sep 19, 2008 | 05:33 AM
bambino's Avatar
thanks a lot... I guess I have my little project for the weekend.. Hope you get yours fixed too...
Old Sep 29, 2008 | 01:56 AM
Akodo Jed's Avatar
The passenger side fuse box (at least, on an 04 Max) is under one of those plastic covers on the left hand side. Once you get the cover off (pop screws, just lift the center part, twist and they should come right out) it'll be just above the coolant reservoir.
Unfortunately, I can't seem to find a fuse diagram for it on the internet anywhere, but you're having the same problem I am currently. I imagine it's a fuse that's blown, I just need to get some daylight so I can check 'em all without a billion flashlights.
--Jed
Old Jun 12, 2010 | 05:42 AM
aramos715's Avatar
any one have a diagram for a 1995 max fuse box under the dash driver side ,,,
Old Jun 12, 2010 | 05:45 AM
Ami Creations's Avatar
If you look on the cover it will list what each fuse is.
Old Jun 12, 2010 | 05:46 AM
You will need to use a multi meter to test your fuses just because it may not look blown does not mean that it is not.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
