6x9 on the rear deck?
Old Sep 25, 2008 | 01:08 PM
danger300z's Avatar
I pick up some 6x9 pioneer to put in the rear deck, But now I notice that I might have to do allot of cuting to make this happend. Any of you guys have successfully install them on the rear? any help or thoughts would be greatly appreciated.
Old Sep 25, 2008 | 02:48 PM
navigator82's Avatar
crutchfiel.com have the adapters like for 10 dlls
Old Sep 25, 2008 | 03:24 PM
Jasovanni's Avatar
OK, disregard the crutchfield adapter post.
I had a pro audio shop install 6x9's in my rear deck. Yes they had to cut holes.
They also installed some custom-cut carpeted plywood mounts for the speakers to screw into and to be honest they sound great. No rattles if you tack down the rear deck cardboard real well. I honestly jam a foam wedge between the deck and the rear window and it applies enough pressure. No it doesn't look ghetto.
One thing to mention tho. I lost my center seatbelt in the back... simply not enough room for the speakers otherwise. Easy decision for me but heads up.
I was also advised as tempting as it would be to wire a 6 speaker system using the rear doors there's no way its worth it $ wise or acoustic wise.
End result for me was an awesome system. Great midbass using components up front and 3 way 6x9s in the back. Not sure how hard the job would be to do yourself, but i didn't get any major complaints from the shop... granted these guys are good at what they do.
Lemme know if you need pics.
J
Old Sep 25, 2008 | 04:24 PM
AEMAXIMA01's Avatar
J
I'd like to see some pics!
Old Sep 25, 2008 | 04:44 PM
ZIPPIN's Avatar
Mauja He Mauja
Did you consider mounting them from under the deck and save the center belt? Smaller hole, mount from truck, save belts
Pics would be nice..
Old Sep 25, 2008 | 04:54 PM
danger300z's Avatar
yeah thanks for the reply, I would like to see some pics as well.
Old Sep 25, 2008 | 04:56 PM
danger300z's Avatar
that sounds like a good idea but I dont think there is enough space to save the seatbelt.
Old Sep 25, 2008 | 05:19 PM
Jasovanni's Avatar
bam
speakers are JBL power series... great line of speakers btw...
Old Sep 25, 2008 | 05:21 PM
Jasovanni's Avatar
btw note how close they came to having to take out the passenger side belt....
J
Old Sep 25, 2008 | 05:27 PM
Feldman's Avatar
i dont see why they had to take out the center belt... i see the hole from above and below but dont see a reason that it had to be removed.
maybe you can make this more clear
Old Sep 25, 2008 | 05:33 PM
Jasovanni's Avatar
i believe its because they had to cut out a mounting bolt hole or two but i could be wrong... or perhaps its due to the fact that the rear deck just lost some serious structural integrity... Now that I look back at it, from the top view it looks like the housing wouldn't fit with the wood plank there but i really don't have another maxima to reference with the belt in place at the moment.There may be a way to save it, build a bracket, cut some wood or something. Its not important enough for me to dabble with so I haven't really messed with it honestly. If anybody has any evidence I should try to pop it back in, I can give it a shot and report back...if i can still find all the parts.
J
Old Sep 25, 2008 | 05:36 PM
Feldman's Avatar
gotcha, now that i look more closely i only see one more mounting hole
Old Sep 25, 2008 | 11:54 PM
hot_wax_tree's Avatar
bam
Looks nice man
but seriously this isnt that hard.
You can take a plyers or a jigsaw, or die grinder and just cut out a little bit. mount them from the top by drilling new holes and your good to go.
Old Sep 27, 2008 | 12:32 AM
hi-tek22's Avatar
how much did they charge you to mount both 6x9 in speakers
Old Sep 29, 2008 | 09:49 AM
pikers's Avatar
Such an invasive procedure for such a horrible sonic result.
Of course I shouldn't type this, because it will just bring out the "stage up-front" *****, but I wonder what people think will happen when they install "6x9 Pienerrrs" in the deck.
This isn't 1988
Old Sep 30, 2008 | 08:43 AM
Reece616's Avatar
i added some 6x9's to my rear deck a while ago, but i went at it a little different.
i dunno if that's something you'd wanna do tho
Old Sep 30, 2008 | 10:40 AM
nismos14's Avatar
§è~® f®ÈÄk
That looks awful.
Oh the humanity
Old Sep 30, 2008 | 12:38 PM
Reece616's Avatar
Originally Posted by nismos14
That looks awful.
Oh the humanity
how would you have done it differently?
Old Sep 30, 2008 | 02:04 PM
AscendantMax's Avatar
I don't think nismo was addressing your setup Reece...looks like good fiberglass work was done.
As for losing the rear seat belts...that's just a stupid idea imo. I wouldn't have done it if i was the shop owner.
Old Sep 30, 2008 | 06:28 PM
travmaximas1998's Avatar
if u wont rear fill just run some good 6 1/2" no cutting required, and u should be very satisfied, i dont know what is the hype in 6x9s!
Old Sep 30, 2008 | 08:27 PM
Reece616's Avatar
oh. yea, i just assumed he was since it was after my post... i thought mine looked pretty nice, but i'm slightly biased.
Old Sep 30, 2008 | 08:35 PM
nismos14's Avatar
§è~® f®ÈÄk
race yours looks good, however I would have made it MUCH more stealth.
Just the concept as a whole irks me.
Old Oct 1, 2008 | 03:49 PM
danger300z's Avatar
Reece that setup dosen't look bad ,but personaly I was looking for something more "stock " looking. Btw how if your visibility?
Old Oct 1, 2008 | 06:52 PM
Reece616's Avatar
a more stock look wouldn't be bad. i would mount them from underneath (in the trunk) if you can/ decide to do it, so you dont have any space issues and to maintain a more stock look.
visibility is fine. the only thing different is i can see the reflection of them in the rear window but i kinda like it
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
