Replacing GF's Bose HU - 4th gen.
Old Sep 29, 2008 | 07:19 AM
Coolsaber57's Avatar
I'm sure this has been answered somewhere, but I was looking at this thread: http://forums.maxima.org/audio-elect...nt-thread.html
And bought the Metra 70-7551, which looks like it has two wiring harness, with two RCAs on the end going into the HU.
Now, if her HU only has one set of Pre-outs, how should I hook this up? Would a splitter work?
Or should we be looking into getting a new HU? Sorry, I've never dealt with Bose before, and she needs a HU with iPod integration.
Thanks!
Old Sep 29, 2008 | 07:30 AM
nismos14's Avatar
§è~® f®ÈÄk
Would be better to have a HU that has 4 outputs. Or you could use a splitter but then you're splitting the output voltage of the HU in half, which means likely that the HU is 2-4 volts and so you'll be getting 1-2 volts per side.
Old Sep 29, 2008 | 07:40 AM
Hmm, that's what I thought. I'm not even sure which HU she has right now...maybe I can convince her to sell it if it doesn't have 4 outputs.
Old Sep 29, 2008 | 07:43 AM
nismos14's Avatar
§è~® f®ÈÄk
And get something with 4 volt pre outs, like that kenwood in the FS section, or if you are feeling spendy.. the 800prs I'm selling
Old Sep 29, 2008 | 07:53 AM
Lol....not sure what the budget is going to be yet. Also, I may get lucky (not in that way, lol) and it may have 4 pre outs. However, if we are in the market I'll keep ya in mind
Thanks for the help nismos14
Old Oct 8, 2008 | 10:57 AM
Ok, I'm looking through the install thread for replacing the bose HU, and I just need some clarification on the grounds situation.
So far there are 3 grounds: 1 from each Metra harness, and 1 from the new HU. Are they all grounded to the chassis via the frame? Or do you not ground the ones from the Metra Harnesses?
Also, is there a solution for popping or alternator whine when replacing the bose? I've been reading that some people have a problem with that after HU replacement?
Thanks guys.
Old Oct 9, 2008 | 07:18 AM
Bump
Old Oct 9, 2008 | 07:21 AM
nismos14's Avatar
§è~® f®ÈÄk
No need to bump.
Ground the one thats coming out of the radio's harness directly to the chassis.
Old Oct 9, 2008 | 08:07 AM
So you don't do anything with the grounds on the metra harnesses?
Old Oct 14, 2008 | 11:42 AM
I hate to bump, but I'd like to know this before I do it.
Are there three grounds for this setup? All grounded to the chassis?
If it's just the HU grounded to the chassis, what do I do with the other two coming out of the metra harnesses?
Old Oct 14, 2008 | 08:52 PM
kpr10is's Avatar
I ground em all. There typically isn't a factory wire in the corresponding pin of at least one of the two spots where your two metra wires are, but it makes life easier to just ground em all in my opinion (because as an installer I often prep the harness prior to removing the stock radio)
Old Oct 15, 2008 | 05:43 AM
Excellent, thank you sir!
Old Oct 15, 2008 | 08:06 AM
Max_Gator's Avatar
I'm replacing the bose in my 96. Why are 4v preapms better than 2? Does it make a huge difference?
Old Oct 15, 2008 | 08:14 AM
nismos14's Avatar
§è~® f®ÈÄk
Ease of install, you just need the metra 70-7551 then, the price difference between a 4 v headunit and a 2 v is pretty negligible nowadays.
MikesChevelle
Nov 23, 2024 11:17 AM
melteye
May 16, 2016 12:02 AM
Finkle
Sep 27, 2015 09:53 PM
mls277
Aug 11, 2015 07:18 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
