Need Help
Old Nov 10, 2008 | 11:19 AM
JPIZZLE's Avatar
Need Help
Well I went into my car today and found out I had a dead battery. Well I got my Car jump started I turned the radio on and got a 60hz note through all of my speakers at full blast. It wont tunr off until I shut the car off. So i disconnected my power wire from my battery.
What I have is the JL Audio sound proccessor that runs to my 3 jl audio amps and a set of Dyns in the front with a w6 in the rear.
I have a 6 disc factory changer in a 2006 maxima with NAvigation
Any ideas of what it could be
Old Nov 10, 2008 | 11:30 AM
CustomLowz's Avatar
do you still get the sound if you pull the RCA's of the 4 channel amp?
Old Nov 10, 2008 | 03:19 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Bypass the processor? Im guessing this is a cleansweep? If so, you know you dont need it right bud?
Old Nov 10, 2008 | 04:46 PM
JPIZZLE's Avatar
Okay hear is what I did so far.
I disconnected all power sources and did a simple turn on the individual equipment. I turned on the processor and then the clean sweep, and the sounds still come from the clean sweep with power on the amps. Amps are on and the sound comes out of the speakers still. Th 60 hz note, no good on my end. SO PEARL, i have spoke to you on this almost a year ago. I was advised from some one else that with the Navigation on the 06 you could not go straight RCA from the Head unit. NOw is this guy just was 100 % certain on this but i am not sure! NOW AT THIS Point i HAte clean sweep and want to get rid of it. What is the easiest way to test and see if the 06 maxima does have a signal coming out of it!
Old Nov 10, 2008 | 04:57 PM
Pearl96Max's Avatar
We can use actual names here John.
Not sure what/how he exactly informed you, but he is not 100% correct, not even 10%.
The signal from the HU (whether Nav or not on Blose) is flat and unamplified. A simply splice in that line -before the amp- will give you preouts. Even Manville @ JL can confirm this.
Gimme a call if you'd like to discuss ... 732-572-1969 or leave me your number.
Old Nov 10, 2008 | 07:38 PM
JPIZZLE's Avatar
I will call you in the AM
tHANKS mIKE,
Old Nov 13, 2008 | 11:39 AM
JPIZZLE's Avatar
Update::
I bypassd the summing device and tested out all the leads from the radio so the processor will only accept 4 leads, FRont and Rear so I tested those leads and we have a winner. But it is not 100% Fixed. the Summing device is out but I am only getting a partial time correction from the digital sound processor. I will re look at it this weekend!
Old Nov 18, 2008 | 10:48 AM
JPIZZLE's Avatar
MORe HElp Needed:
I freaking went to jump start my car and my Alarm with the remote start does not work. Anyone know if there are any or a ton of fuses for the VIper 791XV. Thanks All!
Old Nov 18, 2008 | 11:19 AM
kpr10is's Avatar
There are a few fuses on the wires that run from the alarm brain to the ignition harness, but I find this fishy to begin with. Something doesn't really add up, so Id be interested to see what the problem is.
It is totally dead? Like no lock/unlock, no LED lit up, no nothing at all?
Old Nov 18, 2008 | 11:49 AM
JPIZZLE's Avatar
Nothing everything is DEAD, it looks like it happened when i used my Remote for the alarm to start the car instead of gettin in. What a idiot. But nothing is coming on not even the LED, I will test all the wires tonite and see what happens
Old Nov 18, 2008 | 11:51 AM
Pearl96Max's Avatar
Have you checked the brain itself? Perhaps the primary harness came loose? When you start with the key does the auto lock/unlock engage?
Old Nov 18, 2008 | 11:56 AM
JPIZZLE's Avatar
it engages but it did that before the i had the alarm on it! BUt i will double check it again. How would it become loos if I never touched anything!
Old Nov 18, 2008 | 11:58 AM
Pearl96Max's Avatar
Vibration if it wasnt completely secure to begin with. I thought OEM only did it when the tranny was engaged?
Old Nov 18, 2008 | 12:06 PM
JPIZZLE's Avatar
you are right. that is what still happens now when i put the car in drive It used to do it when i applied the brake!
now it doesnt. SO you think the brain is loose. Even though it worked before i had to jump start the car
Old Nov 18, 2008 | 12:07 PM
Pearl96Max's Avatar
Its very possible. Although you could bring it back to the installer and have them swap the brain ...
Old Nov 18, 2008 | 12:14 PM
JPIZZLE's Avatar
downside of the installer is it was installed at tweeter as you probably know and they have no more installers all laborers in MD were either let go or asked to take a sales position to liquidate the inventory
Old Nov 18, 2008 | 12:18 PM
Pearl96Max's Avatar
Bring it to the next closest dealer then. They may charge you a bit for labor, but you have a lifetime warranty on the unit itself.
Old Nov 18, 2008 | 02:12 PM
JPIZZLE's Avatar
What about you. say if i drive up to your shop have you re hook my radio up and look at it
Old Nov 18, 2008 | 02:20 PM
kpr10is's Avatar
Full custom Stereo complimented with a pair of 3 way Dyna Audios
He might consider it if you can correctly spell the equipment in your sig.
Or is Dyna Audio a knock off that I don't know about?
Old Nov 18, 2008 | 02:48 PM
JPIZZLE's Avatar
I just realized that and I am going to fix
