Woofer drop out
Old Jan 20, 2009 | 06:24 PM
Ridiculous's Avatar
Woofer drop out
I have two 10 inch Type-R woofers and a 1200 watt amp. Sometimes the woofers just seem to shut off. any comments would help.
Old Jan 20, 2009 | 06:48 PM
filtor1's Avatar
When do they shut off? After beating on them pretty hard or just randomly regardless of duration and volume level?
Old Jan 20, 2009 | 07:34 PM
Ridiculous's Avatar
seems to be random
Old Jan 20, 2009 | 07:44 PM
travmaximas1998's Avatar
i would guess
possibly lose rcas or remote wire
can u keep an eye on your voltage?
Old Jan 20, 2009 | 09:18 PM
djfrestyl's Avatar
Suspension Yoda
Wiring for sure. Could even be the speaker wiring, depending how they're wired.
Old Jan 20, 2009 | 10:00 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Too low of impedance and the amp is going thermal ?
Old Jan 21, 2009 | 09:30 AM
Ridiculous's Avatar
what if it did happen when i turn up my music? cause it happened today when I turned it up but it could be a coincidence.
Old Jan 21, 2009 | 11:28 AM
djfrestyl's Avatar
Suspension Yoda
Either the amp is going into protect or the sub is rattling a wire loose.
Check the amp next time it happens.
Old Jan 21, 2009 | 11:39 AM
Pearl96Max's Avatar
Me thinks the load is too low.
Old Jan 21, 2009 | 03:43 PM
djfrestyl's Avatar
Suspension Yoda
That's what she said.
Old Jan 21, 2009 | 07:13 PM
doylerules826's Avatar
I have this problem to and my amp is rated at 2 ohms and i have my subs wired like this http://akamaipix.crutchfield.com/ca/...4-ohm_mono.jpg
the protection light also blinks when the subs hit really hard
Old Jan 21, 2009 | 07:16 PM
f550maranello2's Avatar
check the ground.. i bet its not good and causing the amp to shut off....
or the 12 volt trigger from the radio
Old Jan 21, 2009 | 09:15 PM
Pearl96Max's Avatar
Ouch, I shoulda saw that one coming.
Old Jan 22, 2009 | 07:23 PM
djfrestyl's Avatar
Suspension Yoda
To the OP, did you figure it out yet?
Old Jan 23, 2009 | 08:02 AM
nishfish871's Avatar
Looks like you are clipping your amp. Turn the gain down a bit. Maybe the excessive clipping makes it go into protect.
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
