95 audio catastrophe!
Old Mar 15, 2009 | 06:31 PM
95.maxima's Avatar
ok so i got a new HU today. finally got it all set up and it is working. im going little by little to fix all the issues in my car. for as long as i can remember the rear speakers havent worked. no biggie i thought they were blown. well i hook up the new speakers i have and i get static out the ***. the volume doesnt change the static noise or anything.
after a while of searched im here posting this. the bose speakers dont work and neither do the new ones. i tried 4 different ones and they all do the same. the front speakers (the old bose that will be replaced soon) work great with the new HU.
anyone have any ideas?
edit: after a quick test, the rear drivers side works with the aftermarket speaker. however its the rear passenger side that just spits out static when plugged in.
Old Mar 15, 2009 | 06:47 PM
This is the reason why I still have my stock Bose system. Its a PITA.
Old Mar 15, 2009 | 06:53 PM
95.maxima's Avatar
yes it is... yes it is.
but sadly my front two speakers are blown. i have 4 61/2s from my civic laying around and spring break this week with no work till friday. so im trying to fix her up this week. one big thing that needs work is the audio and im tired of listening to talk radio and the voices making the speakers rattle. heh
so here i am
Old Mar 15, 2009 | 07:44 PM
BLACKonBLACK98's Avatar
Former Vendor
that static is probably because of a malfunctiong bose amplifier. are you wiring the speakers in before or after the factory amps? if your answer is after then try before.
PITA > POS
Old Mar 15, 2009 | 07:47 PM
Originally Posted by BLACKonBLACK98
PITA > POS
Bose is good IMO.
Old Mar 15, 2009 | 07:55 PM
95.maxima's Avatar
PITA > POS
ok.. so i think your right on that. i found a little more info on this and this seems to be the logical answer to me also. because i have only tried it after the amp.
HOWEVER, if the aftermarket speaker works after the amp on the drivers side, why would the passenger side be down? i think this is the part thats confusing me.
Old Mar 15, 2009 | 08:56 PM
Former Vendor
because only one of the amps is bad.
good amp = good sound
bad amp = bad sound
Old Mar 15, 2009 | 08:58 PM
Former Vendor
Bose is good IMO.
"IMO" saved your statment. it may be good enough (it was for me at one time) but in actuality it is far from good.
Old Mar 15, 2009 | 11:01 PM
95.maxima's Avatar
bad amp = bad sound
ya i did some research (for about 4 hours) to find this out really. im gonna rip my car apart even more tomorrow and hopefully get this settled. and in all honesty this has been the biggest PITA system i have ever dealt with in my life. heh
Old Mar 16, 2009 | 12:05 AM
95.maxima's Avatar
ok so now only the passenger front speaker works. the driver front DID work but now it is EXTREMELY quiet. in order to hear it at all i need to turn it all the way to the left in order to barely hear it.
pfffft
Old Mar 16, 2009 | 02:00 PM
Former Vendor
step 1) pull out everything bose
step 2) install everything aftermarket
Old Mar 16, 2009 | 09:59 PM
95.maxima's Avatar
check out my new thread
Old Mar 17, 2009 | 12:55 PM
Congrats fixing it.
Old Mar 22, 2009 | 06:02 PM
JSpizzy203's Avatar
I just joined today. I have 1999 Max SE. Factory System in car. I had "professional" install adapter to system so he could install amp and subwoofers. Only one sub works after professional installation. He blamed amp. So I replaced amp with another brand new amp, Once again only Right sub works, "professional" said to bridge Left sub wires with Right sub wires. I was upset b/c its a patch work job, I could have done it myself, I paid $300 for installtion and I had to accept supar job. Then today I cleaned my battery posts because Ihad trouble starting car, and I added water to my battery beause it was empty. Then I drove 1/2 a mile and then neither sub was working. Came back, playes with some things, the LMP/HMP switch was in OFF postion, I switched to LMP poistuion and only had Right sub plugged in, got it to work but its reall weak. No fuses are blown, its like one thing after the other. I thought this would be a Plug & Play situation. This makes no sense.
Old Mar 22, 2009 | 08:52 PM
95.maxima's Avatar
sounds like they left the amps in assuming that you have a bose system. if you ahve the bose system and they did leave the amps in it could very easily fry your new stuff. i would find out exactly what i did and if they didnt wire around the amps tell them to buy you new stuff.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
