power antenna replacement
Old Apr 2, 2009 | 06:32 PM
thomatt12's Avatar
I'm not really sure if this is the right section to ask but I just want to know where I can get power antenna replacement for my Maxima. The motor of the old power antenna just broke off and I need a replacement. Thanks!
Old Apr 2, 2009 | 09:42 PM
JNCoRacer's Avatar
Just the tip.
The motor or the mast?
Old May 10, 2009 | 08:01 AM
nymax99se's Avatar
did you finally get it replaced? because i just broke mine off when i went into the car wash.
where did you get it?
Old May 14, 2009 | 06:47 PM
maxprivate's Avatar
Black Lion
you can probably find them at courtesy Nissan. Or try your local junk yard, Im sure these are common parts.
Old Jun 1, 2009 | 03:10 PM
TheGreek's Avatar
I've got a similar issue, my antenna has just stopped going up. When I turn on the radio I hear the motor trying to work but the thing doesn't move. I think this is a prevalent problem among Maxima owners so any advice you have I would really appreciate. Thanks
Old Jun 1, 2009 | 05:14 PM
haydeno's Avatar
I recently got a new mast off ebay for about $20, works fine
Old Jun 1, 2009 | 08:12 PM
JNCoRacer's Avatar
Just the tip.
Ive had to replace a few of these. Most of the time the mast can just be replaced. A couple times I had to take the motor apart and pull out the broken gear pieces of the mast extender. Thats a good time to clean it up, regrease it, and also clean out the drain tube for when it rains or the car is washed.
Old Jun 2, 2009 | 12:27 PM
TAPOUT's Avatar
You will lose
It is a broken "Mast and Cable assembly" that you need to get from the dealer, or from a junkyard. You will need to remove your antenna completely from the car and open up the motor to remove the old cable. Then reinstall the motor, and feed the "Mast and Cable assembly" down as someone turns the radio off. Then put the locking nut back on, and you are done. It is very easy to do, but will take the better part of an hour if it is your first time.
MikesChevelle
Nov 23, 2024 11:17 AM
hydriplex
Aug 28, 2015 02:13 PM
maxinout93
Aug 20, 2015 02:17 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
