People with Optima Yellows
Old Nov 19, 2001 | 08:09 PM
Kevin Wong's Avatar
Did you guys notice the car cranks up faster? I'm not sure if it was because my stock battery literally had the life sucked dry from it, but I can't recall the car ever cranking so fast.
Old Nov 19, 2001 | 08:28 PM
GarthG's Avatar
Mine didn't seem to crank faster, although my starter was going out at the time I upgraded to one, so that might have been a problem
Old Nov 23, 2001 | 01:59 PM
MaineI30's Avatar
no
no noticable crank change here
Old Nov 23, 2001 | 06:49 PM
Nick97SE's Avatar
Just installed my Optima Yellow Top a few days ago, and YES...there is a difference. The car starts a lot faster now. When I start it, the tachometer jumps to 1 really fast.
-Nick
Old Nov 23, 2001 | 06:57 PM
ny96max's Avatar
yes.... huge difference between the stock battery and the Yellow Top
Old Nov 24, 2001 | 12:17 AM
SWEETSOUND2001's Avatar
It just cranks right over. I definately noticed a difference.
Old Nov 24, 2001 | 12:24 AM
Shadow's Avatar
Don't have a yellow top. But when I installed my Holley Annihilator race battery, the car cranked a whole lot faster than with the stock battery.
Old Nov 24, 2001 | 12:30 AM
Kevin Wong's Avatar
Great!!!
I just wanted to make sure I don't have a funky battery. Everything has improved with this cure-all battery...no more slow power windows, power antenna, and worry-free starts. I had about 50K miles on my 97 stock battery. I started recharging it, but I could tell it couldn't hold the charge and was going to die soon. I totally love my yellow top; no regrets.
Oh yeah, does anyone know how long these optimas should last?
Old Nov 25, 2001 | 12:54 AM
Quack 2x's Avatar
Re: Great!!!
The Yellow top I've been using has lasted two years under rather severe useage. Using a friend's original Red top as a benchmark, it should last you well over six years with hard use, including several jump starts from his forgetting to turn his lights off, running his stereo without the motor on, etc...
The Optima was so dead it couldn't even turn on his dome light, and it jump-started right away. Most normal car batteries would probably not have survived a drain like that, but the Red top recharged and has been working fine ever since. His battery has outlasted two cars and is going on it's seventh year.
Hope this helps,
Quack2x
Old Nov 25, 2001 | 01:09 AM
Quack 2x's Avatar
Re: Great!!!
Hope this helps,
Quack2x
Old Nov 25, 2001 | 02:46 AM
vteckilla's Avatar
hey is it possible to use a blue top as my main batterie a yellow top
wouldnt macth my blue accents in the motor. sorry had to
use a new smiley!
Old Nov 25, 2001 | 11:02 AM
Quack 2x's Avatar
use a new smiley!
heh...
don't see why not, if you are willing to spend the extra money for the Blue top, or really need deep-cycle marine battery.
If money is a factor, and you weren't running a lot of equipment that put a large drain on your system, you would be just as well off with a Red top (Costco, $99.99) and painting it to match.
hope this helps,
Quack2x
Old Nov 25, 2001 | 05:40 PM
vteckilla's Avatar
painting a batterie?the things we do just to have perfection.
anyone wanna tell me the technique of painting a batterie lol.
Old Dec 7, 2001 | 10:09 PM
NICOLE's Avatar
Re: Great!!!
well i didn't get the yellow top i got the red top battery
because 2 people told me that the yellow isn't to be used as a main
battery
Old Dec 8, 2001 | 11:59 AM
The only difference between yellow and blue top is that the blue top has terminal with thread on them.
Anton
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Fbana41
Aug 29, 2016 12:18 PM
REDinLV
Sep 28, 2015 12:31 AM
