Nissan antenna adapter 12040NI12 blue wire question
Old May 10, 2009 | 07:59 AM
1hawaii50's Avatar
What do I attach the blue wire from the antenna adapter to? I've read where it should go to the radio wire harness remote turn on lead, and I've read where it should go to the radio wire harness power antenna lead. This is going into an 07 Maxima. I tried searching here, but couldn't find anything.
Old May 10, 2009 | 09:22 AM
nismos14's Avatar
§è~® f®ÈÄk
Radio wireharness, if your radio only has a remote wire then wire it to the remote.
Old May 10, 2009 | 05:34 PM
07Maximan's Avatar
Are you using an aftermarket deck?If so there should be a solid blue wire in the harness.If you dont attach the blue wire you wont be able to get any reception.
Old May 10, 2009 | 06:22 PM
1hawaii50's Avatar
Yes, I'm using a Pioneer DEH-P980BT along with the NIRD-01 interface. The Pioneer harness has one blue/white wire labeld "system remote control", the metra harness has a blue/white wire labeled "amp turn-on".
Old May 10, 2009 | 08:11 PM
07Maximan's Avatar
No it should be just a solid blue wire.I had a Pioneer F700BT and it had the blue wire.You only need the blue/white wire if you re using the stock Bose speakers.Are you looking for the wire on the HU wiring harness?
Old May 11, 2009 | 02:04 AM
1hawaii50's Avatar
Yes, the Pioneer harness that came with the head unit only has a blue/white wire that is labeled "system remote control". There is no solid blue wire.
Old May 11, 2009 | 05:18 AM
nismos14's Avatar
§è~® f®ÈÄk
Read above.
Connect it to the remote turn on.
Old Sep 10, 2009 | 08:12 PM
akattamu's Avatar
Read above.
This works? I have the same issue, Pioneer HU, no blue ant wire, but it does have the B/W system remote. I guess this is a constant 12v power, of a lower amperage? I was thinking of splitting power from the ACC supply, but that seems like a bad idea.
Old Sep 15, 2009 | 07:34 AM
Calcvictim's Avatar
Connecting to the remote turn on will work fine. I have a JVC deck and Bose so I need to connect both the power antenna wire and the amp turn on wire but the deck only has one wire, I connected both wires to the remote wire on the deck and everything works fine.
Old Oct 20, 2009 | 09:57 PM
pat63's Avatar
I have also problem with my nissan antenna.. my antenna connector doesnt align..the female on the pioneer has one prong.. i just want to ask what do i still need to complete the wiring.. thanks!
Old Oct 21, 2009 | 02:44 AM
1hawaii50's Avatar
Did you get the Metra antennae adaptor?
Old May 23, 2010 | 05:18 PM
stjo's Avatar
Is this the appropriate adapter for '97 Maxima GE w/o Bose?
Metra 40-NI11 Non-Diversity Nissan Antenna Adapter
Old Jun 14, 2010 | 04:57 PM
Rods03Max619's Avatar
To That its fairly simple match up!
MikesChevelle
Nov 23, 2024 11:17 AM
schmellyfart
Sep 25, 2015 04:47 PM
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
98nismomax
Aug 13, 2015 12:44 PM
